Power surge on hub Port
Discussion in 'PC Hardware' started by SVEN, 2009/08/08.
  1. 2009/08/08
    SVEN
    SVEN Well-Known Member Thread Starter
    Hi guys,
    Got a problem on my laptop.
    I am getting the following pop up:
    A USB device has exceeded the power limits of its hub port.
    For assistance in solving this problem, click this message.
    After I click on it, it opens another dialog box telling me to unplug the USB device and click on "resetâ€. After I do that it closes and the first pop up comes back again, even though there is nothing plugged in, not even the power supply.
    Any idea how to solve this
    Sven
    SVEN,
  2. 2009/08/08
    General opinion on 'A USB device has exceeded the power limits of its hub port' on Google suggests it's nothing to worry about.
    Solution ....
    Device Manager > Expand USB Controllers and double click on each controller in turn > Advanced tab and check 'Don't tell me about USB errors' :)
    SVEN
    Thanks Pete, will do
    Sven
    SVEN,
    SVEN
    Hi all,
    I marked it as unresolved again because I found out that this has something to do with my screen. Whenever I adjust the position on it, it gives me that message.
    Even if I move the laptop just a little and it just shakes the screen, I get that message.
    Could it be there is something loose inside and shortens out when I move it?
    Any one?
    Sven
    PS: I will be out of the country and will not be able to read any response till 8-18-09
    SVEN,
    Sounds more than likely to me, but I am surprised that the setting I suggested does not work even under these circumstances.
  7. 2009/08/12
    SVEN
    Pete,
    I could not find the setting you recommended, but while trying to go there, i found out about the screen.
    is the screen part of the USB connections?
    Sven
    SVEN,
    #6
  8. 2009/08/12
    No - it is hardwired to the motherboard - think of it as a permanent D-Sub connection.
    see screenshot ....
  9. 2009/08/19
    SVEN
    Hi Pete,
    I am back in the US and looked at your atachment and the PCI to USB controller is OK. my USB ROOT HUB #3 is the problem. I can disable it, but then none of the USB ports works.
    Or it could be that I am just not getting what you are telling me.
    Please clarify
    Sven
    SVEN,
    #8
  10. 2009/08/20
    My attachment shows where to disable USB error notification - do not disable the controller or some USB ports will not work - all if you only have one controller:)
    Not clear if you are disabling Root Hub #3 or the controller :confused:
  11. 2009/08/20
    SVEN
    Hi Pete
    I am just disabling the Root Hub #3 and all usb ports in back will not work.
    I will try to just disable the error notification when I get home.
    Thanks Again
    Sven
