power supply does not work after upgrade
Discussion in 'PC Hardware' started by jongru, 2002/01/31.
  1. 2002/01/31
    jongru
    jongru Inactive Thread Starter
    I Posted prior about the compaq presario 7940 upgrade. I went to a local computer store and bought a 350 watt power supply, I installed it into my computer and it wouldn't work.
    I took it back and they said I needed the workaround for the push button connection on the front of my computer to start it. I reinstalled my old one, fine. I think the problem is that the power-on button connected to the motherboard must be the problemon the new power supply. Is there anyone who did this before, please advise.
    Thanks, jongru...
  2. 2002/01/31
    Rancher
    Rancher Inactive
    psu
    Is this the person that is replacing a 200w?
    If so is your board AT or ATX? The power supply connects to the female jack on the board & the power on switch connects to the mainboard, on ATX interface. A momintary switch, push but doesn't click like a toggle would, is on the newer cases & goes to two pins on board. Now.....you prolly have the hard switch (click) rite?
    jongru
    Power Supply replacement
    Hi Rancher,
    Thanks for the input, I believe my push button on the front of my compaq is the newest type power on switch. From what I am reading from other compaq users is that the cable connectors have about 21 pins. I don't know how many are actually used. I would still like to keep the button in use. Just need to know if there is a workaround or modification to the motherboard plug from the normal atx power supplies....thanks...jongru
