power pack trouble
Discussion in 'PC Hardware' started by lanime, 2005/09/11.
  1. 2005/09/11
    lanime
    lanime Inactive Thread Starter
    hi team i have an old
    sys with win 98 installed
    it only had a
    1.58 hdd
    so i tried to install another hdd .
    now the compt wont power.up. tho
    . my monitor is alive
    ive tired different power points
    .but it is dead
    does any one think the hdd has corrupted the
    powerpack.
    or is their some way i
    can test the power pack
    the compot is so old
    that even the powerpack fuse is soldered to the pack
    i do not want to get rid of it as it
    has helped me to solve several problems.
    but. as ime not a
    power person.
    i need advice.
    thank you
    166cpu
    1.58hdd
    win 98 installed
    i hd it connected to the internet .
    i hope ive explaijned this clearly.
    marty
  2. 2005/09/11
    sparrow
    sparrow Inactive
    Sounds like you have a short circuit. Take out the disk and start over. If you haven't, check all the cables to be sure nothing has come loose. Make sure the ribbon cable has the stripe along its side on the side toward the power cable. Also turn the box over so the opening is down to make sure no hardware has been left inside. Then see if it will power up.
    lanime
    powerpack
    im not sure what is happening
    but i posted this 2hrs ago
    and when i sent the post. i got an error message
    this has happened several times
    .i belong to another board .
    and they are having the same trouble.
    ok i did as you instructed
    and i took all the cards and components out
    all but the mobo .
    then i replaced them back one by one.
    the power pack was the one i was worried about
    but once i installed the hardware.
    i pressed the power button.
    and bingo it was away .
    i cannot tell you what was the matter with it .
    it is going and thats what matters.
    the compt dosent belong to me, it is a friends
    and he loaned it to me.
    ive solved quite a few problems because of it
    but this time i thought it was history.
    how ever thanks for your input .
    im not a fan of win 98
    but it does serve its purpose.
    marty
  5. 2005/09/12
    sparrow
    sparrow Inactive
    Good work. Thanks fot the reply. Glad to help.
  6. 2005/09/12
    lanime
    appoligy
    i have to appoligise for posting in the wrong forum.
    i didnt think of hardware.
    thanks
    marty
