Power managment help
Discussion in 'Windows XP' started by eagleheart, 2006/01/14.
  1. 2006/01/14
    eagleheart
    eagleheart Inactive Thread Starter
    Im trying to play a gam but it says that the processor is set to change speeds according to programs, and i have to change it in the power managment but i cant find power managment, its not in my control panal where it should be, do i need to add it or access it from another point please help icant play my game without changing this.
  2. 2006/01/14
    bluzkat
    bluzkat Inactive
    eagleheart,
    It should be in your BIOS... restart your computer and enter 'setup' (varies with different computers, common keys to use DEL of F1 or F2). You should be able to change the option there. If you have a problem, post back with specifics about your computer (manufacturer, processor type, etc.)
    B :cool:
    eagleheart
    I went into the bios and i didnt see any kind of option that would help me as far as i know. I have amd athlon 64 3200+ with a gigabyte mobo. running windows xp pro
  5. 2006/01/14
    bluzkat
    bluzkat Inactive
    Do you have AMD's "Cool and Quiet" installed?
    B :cool:
  6. 2006/01/14
    eagleheart
    no i dont would that help?
  7. 2006/01/14
    bluzkat
    bluzkat Inactive
    Do you have any 'overclocking' programs installed like nVidia's nTune? These have settings that can automatically adjust the processor speed. If so try disabling it.
    If this doesn't help... hang tight, someone will jump in.
    B :cool:
  8. 2006/01/14
    eagleheart
    thanks, but i have nothing that is doing that, it says says that windows has the the processor speed to vary with the programs
    Someone please help
  9. 2006/01/14
    Try this:
    Right click on empty space on Desktop->Screen Saver->Power. There would be a a box saying Power Scheme. Just select Home/Office Desk, click Apply, Ok and close the dialog boxes.
  10. 2006/01/15
    Have you checked in the BIOS that AMD Cool'nQuiet is set to Disabled - you would not necessarily be aware that it is installed. If it is installed the Power Management should be set to 'Minimal power Management' and if you look in Device Manager under Processors the driver provider will be shown as AMD.
    I am away from home and my desktop at present so cannot give you more detail on the driver situation.
  11. 2006/01/15
    eagleheart
    I tried the power options and that didnt work, in the amd bios there is no cool and quiet option, So what else can i do? Thanks for your responses but i sitll need help :)
  12. 2006/01/15
    Are you using a laptop to run this game? Most current laptops have 'mobile' processors which adjust their work rate depending on the load put upon them.
    If this is the case I am not sure offhand where or how - or indeed if it is possible to disable that feature. One solution may be to run on mains power.
  13. 2006/01/15
    eagleheart
    Nope this is a desktop computer
  14. 2006/01/16
    eagleheart
    its a gigabyte motherboard,with an amd athelonprocessor, there is no option in the bios orin power options,any other ideas?
  15. 2006/01/16
    Post the model no.of the Gigabyte board - another user may be able to help. Normally I would download the manual and take a look, but I'm away from home on a dead slow dialup rather than my home broadband connection.
