Windows Vista Power management
Discussion in 'Legacy Windows' started by mike852, 2009/03/13.
  1. 2009/03/13
    mike852
    mike852 Inactive Thread Starter
    Hi, I have a problem with the way my computer reacts to the settings i put in my power management options. I am currently using the balanced power option, and when it hits the limit when the display is supposed to turn off it does fine, but when it hits the sleep limit it doesn't work; the hard drive stays on and the sleep button is on. In contrast, if I manually put the computer to sleep i.e. i push the sleep button, it works fine; I can hear the hard drive go off and the sleep button blinks. Any help would be appreciated.
    Email address removed by Moderator to protect you against spammers. We only asnwer questions on the BBS for the benefit of all. The standard BBS font is preferred for simple reading.
  2. 2009/03/13
    Phildawg2009
    Phildawg2009 Inactive
    Just use the 'Always on' Function if your on a desktop, And just set the PC to turn off the monitor for awhile. if not RAM is required for it to go to Hibernate. Best ram setting: 256 [512 or 1GB reccomended or more]
    mike852
    i don't like to turn off my computer, so i would like it to sleep the way it is supposed to. is there something that would prevent my notebook from sleeping. I can hear it try to sleep; kind of stalls a little and then speeds up; it does this over and over like it is confused on how to sleep. Or in other words it seems that just before it finally sleeps it will then go back on at the last minute; like there is some kind of conflict.
  5. 2009/03/13
  6. 2009/03/13
    mike852
    Thanks Evan Omo. i am going to try all that out. thats a good article.
  7. 2009/03/14
    mike852
    hey Evan. when i first went to that article i thought it was on the same web site cause of the same colors. come to find out its another forum. thats cool cause i need help with this thing.
  8. 2009/03/14
    Ok let me know if that website was able to help solve your problem or not.
  9. 2009/03/15
    mike852
    no i havn't been able to fix the problem. thanks though. i'm sure there will be more.
  10. 2009/03/15
    Try shutting down all backround programs that are running in the system tray in the taskbar (especially anti virus scanners). One of those backround programs might be causing the computer to not go into sleep mode at the requested time.
  11. 2009/03/16
    mike852
    What's up, I finally solved my problem. There is a setting in the advanced power management options under multimedia settings...when sharing media. The default setting doesn't work for my notebook, so I changed it to "allow the computer to sleep." I also downloaded the current display driver which I would of done a long time ago if I new one existed. Point being, those automatic update programs don't always find everything.
  12. 2009/03/16
    Good job Mike. ;) I am glad that you were able to solve your problem.
  13. 2009/03/17
    mike852
    Thanks , I feel allot better now that i am helping to save energy. Without any power management, I had to shut down my notebook all the time during breaks. Now I can just let it sleep which is cool cause it's super fast to resume working. I can't believe the default setting was causing my computer not to sleep. Oh well live and learn I guess.
  14. 2009/03/17
    Yep. ;)
