power editor
Discussion in 'Internet Explorer & Microsoft Edge' started by abx, 2006/10/11.
  1. 2006/10/11
    abx
    abx Inactive Thread Starter
    Can anyone tell me how to get rid of "power editor" re Internet Explorer ". Thank you.
    abx,
  2. 2006/10/11
    Is this the 'Power Editor' you refer to? ....
    http://help.excite.com/mail/power_editor.html
    Nothing here about removing it, but ways of not using it.
    Take a look under Tools > Manage Add-ons > Enable or Disable Add-ons and disable it if present.
    Look for an entry in Add/Remove Programs and uninstall if present.
    abx
    To PeteC: Yes. I have mail.com as my web-based e-mail. The contact person at mail.com said that she does not know how to get rid of it. Can you tell me how? Thank you.
    abx,
    Beyond what I have already posted I have nothing further to suggest. Never heard of Power Editior prior to your post and very little info on Google. Sorry.
  6. 2006/10/11
    abx
    To PeteC: I think I discovered a way to avoid the Power Screen at least on web-based e-mail. When setting up the e-mail account, set it up so that it uses plain text and not HTML.
    abx,
    #5
