Pop Ups Question
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Auntpolly, 2005/05/27.
  1. 2005/05/27
    Auntpolly
    Auntpolly Inactive Thread Starter
    I have almost 1000 pop ups listed as blocked. Is there a way to reset this? I am using NS 7.2. My mother uses the same version and hers resets each time she closes the program. THis is a big thing, but just wondering why hers does and mine doesn't. I installed both and did not do anything different with each install. Thanks. :rolleyes:
  2. 2005/05/27
    Westside
    Westside Inactive Alumni
    :rolleyes: right back! Just kidding. I will have to make some guess, since I don't keep track of the popup. They either go or else, and I don't care to know how many. First guess is that you have the Netscape Toolbar. I don't find it useful, and hide it. I brought it up, and clicked on Netscape button on the left, and selected Options, clicked to reset to zero.
    There is no way that I can keep separate the Netscape Toolbar from the builtin
    Popup controls, so I don't know if it will keep counting, and you can easily reset to. I think that it keeps track of popups even when the toolbar is hidden. Then you can uncheck the popup counter from the toolbar buttons. It will work as long as you keep the unrequested popup buttons checked.
    Now, why is your Mom having it reset every time, I am not sure. May be she does not visit so many sites which give unrequested popups.
    Auntpolly
    It Worked!
    Hey, thanks. I found the option and reset the pop up window. Feel ashamed. :eek:
    I pride myself on hunting for all options with any software and setting it up the way I want the software to run NOT the way the software wants me to run it! :eek: Guess I missed that one.
