**pls help** how to format???
Discussion in 'Legacy Windows' started by uberclueless, 2002/05/26.
  1. 2002/05/26
    uberclueless
    uberclueless Inactive Thread Starter
    I just installed win2000 after formatting win98.
    Now, I would like to format again but there is no DOS in win2000.
    I tried using the command prompt, but it said something about forcing a dismount on the C: and when choose the option "yes ", then it says "cannot lock the drive, the volume is still in use "
  2. 2002/05/27
    Kevin Lifetime Subscription
    Kevin Well-Known Member
    uberclueless
    I fixed it
    actually I fixed it...for some reason my windows 98SE boot disk did not have "format.com" on it so I had to d/l a bootdisk from the net, after that I could just type format c: /u in the prompt when I start up my cpu with the boot disk..
    told you I was a beginner ;O
    thx for your reply kev.
