Please Help, Standby problem!!
Discussion in 'Windows XP' started by nihaojs, 2002/09/15.
  1. 2002/09/15
    nihaojs
    nihaojs Inactive Thread Starter
    Dear Expert,
    After re-install my Win XP, I can't into standby anymore. Following is error info.
    'Device driver for standard keyboard (101/102) or microsoft keyboard will not allow you to exchang to standby mode. Close all application and retry again. If it happens again, update your driver'
    Then mause point disappeared. I have to restart my machine to get it normal.
    I am using Sony Vario PC with P4 1700Hz, XP home.
    Thanks in advance for any advise!
    Haojs
  2. 2002/09/15
    mrdan08
    mrdan08 Inactive
    I experienced this problem when I installed Adobe Acrobat 5.0. When I installed Acrobat, it also installed Adobe TypeManager, and TypeManager was causing the problem. I uninstalled TypeManager and everything has been fine since. If you have TypeManager installed, try updating it or uninstalling it.
    nihaojs
    Thanks, mrdan! After uninstalled adobe type manager, the problem solved!
    Haojs
