Please Help Me Debug Recurring Bluescreen
Discussion in 'Windows XP' started by transitionality, 2009/01/30.
  1. 2009/01/30
    transitionality
    transitionality Inactive Thread Starter
    My OS is Windows XP Pro SP3. I've recently been getting seemingly random bluescreens that I can't associate with any particular application or device. The error message is always the same.
    IRQL_NOT_LESS_OR_EQUAL
    0x0000000A (0x0000001C, 0x00000002, 0x00000001, 0x806E6A16)
    I'd be very appreciative if somebody could take a look at a few recent minidumps and tell me what to suspect.
    http://www.filedropper.com/minidumps
    Thanks.
  2. 2009/01/31
    Welcome to WindowsBBS :)
    Please debug your own logs - we will try to analyse them, but expect you to do the donkey work.
    Note : We have found that the path for the log file in the revised version of the Debug Wizard is incorrect. Please follow these instructions to correct the path and run the Wizard ....
    Browse to the location of your dump file and select it.
    Tick the Advanced button and edit the first part of the 'Command string to pass to debugger' (Screenshots) .....
    Replace -logo c:temp\debuglog.txt with -logo c:\debuglog.txt
    i.e. remove temp
