Resolved PCMCIA USB CARD do not detect Ext Hard Drive
Discussion in 'PC Hardware' started by belcourtoi, 2010/06/12.
  1. 2010/06/12
    belcourtoi
    belcourtoi Inactive Thread Starter
    I have problem using a new PCMCIA USB2 CARDBUS -VIA Technologies- (to get 4 more USB posts) which detects with no problem the mouse, the flashdiscs but not my external hard drive (LG 500GB).
    The hard disc works perfectly when I connect it directly to my lap top.
  2. 2010/06/12
    Is the external hard disk powered separately or drawing power from USB ? If its drawing power from USB, the USB card might not be able to supply the reqd. power.
    belcourtoi
    It's powered from the USB, and I think that you're right because when I used it a hard disc powered externaly it worked normaly.
    Is there a solution for that problem?? Thank you.
  5. 2010/06/12
    Aside from powering it externally I don't think there is any solution to it.
  6. 2010/06/13
    hawk22
    hawk22 Geek Member
    connecting your LG 500 GIG to a powered USB Hub connected to your USB2 CARDBUS, not exactly brilliant.
  7. 2010/06/15
    Return the pcmcia card and get a compact usb hub. I have one for my laptop that I paid about 10 bucks for, it also came with a power supply that can be used if needed be. example
  8. 2010/07/02
    belcourtoi
    I am powering the hard drive from external usb, and it's working properly.Thank you all for your precious help.
