PCMCIA 6-Pin F'wire for Gateway MD2614u
Discussion in 'PC Hardware' started by gplea, 2010/03/18.
  1. 2010/03/18
    gplea
    gplea Inactive Thread Starter
    Gateway refuses to advise me for free on what model PCMCIA 6-Pin Firewire card would be compatible with my laptop. Can any geeks help me here?:confused:
    Thanks,
    GPL
  2. 2010/03/18
    wildfire
    wildfire Getting Old
    This link will maybe help... About ExpressCard.
    What cards are you looking at?
    gplea
    Thanks Wildfire. I don't know what cards I'm interested in. That's why I posted this. I had hoped that Gateway would offer some as accessories, but they want to charge me for advice on something I'm gonna buy from them. How much $en$e does that make? So, I haven't looked at any. I'll check your link out.
    BTW, the laptop uses Vista Home Prem. (64-Bit), AMD Turion X2.
    Thanks,
    GPL
  5. 2010/03/18
    What will you be plugging into the -> PCMCIA 6-Pin Firewire card ?
  6. 2010/03/18
    gplea
    Thanks Steve. I'll be plugging an Alesis I/O26 audio interface into it.;)
  7. 2010/03/19
    Are you certain that your laptop doesn't already have a firewire port? Most all laptops made in last 4 years do have one.
  8. 2010/03/20
    gplea
    POSITIVE! They put an HDMI port on instead. Which that's kinda neat. In fact, that's actually 1 of the main reasons I bought this model cuz at the time I was considering using that feature to troubleshoot home theater issues.
    GPL
  9. 2010/03/20
    gplea
    I checked out the Express cards. So why are they so much more expensive than the PCMCIA? Also, do I understand that the PCMCIA form doesn't support VISTA? I couldn't find any PCMCIA cards that did.
