PCAnywhere compatability issues?
Discussion in 'Other PC Software' started by PDubs, 2003/08/01.
  1. 2003/08/01
    PDubs
    PDubs Inactive Thread Starter
    Does anyone know if PCAnywhere v9.2 will function properly when installed on Win2k Professional clients (SP3)? I'm unable to install Terminal Services, so PCAnywhere would work for me (I like this option better than NetMeeting) as long as there are no O/S issues.
  2. 2003/08/01
    PDubs
    n/m, Answer found from Symantec:
    Full Article
    Note: pcAnywhere 9.x is not compatible with Windows 2000 SP2 or later. You must upgrade to pcAnywhere 10.0 if you have installed SP2 or later. Also, note that uninstalling SP2 will not make Windows 2000 compatible with pcAnywhere 9.x. In order for pcAnywhere 9.x to work under Windows 2000, SP2 must never have been installed. pcAnywhere 9.x is not compatible with Windows XP.
