PC dead, help!
Discussion in 'PC Hardware' started by Soloist, 2017/08/30.
  1. 2017/08/30
    Soloist
    Soloist Well-Known Member Thread Starter
    PC dead, help! No life except for pilot light on front. PSU replaced
    and coin battery changed, twice. PSU green wire to ground test shows PSU ok. XP service pack 3. Any help much appreciated, thanks.
    More info; motherboard Foxconn A6VMX. PSU Corsair CX450W.
    PC working fine but failed to turn on next morning.
  2. 2017/08/30
    Christer
    Christer Geek Member Staff
    My first step would be to verify that the HDD has not gone to see its maker. During startup, I assume that hitting the "DEL" button will bring you into BIOS. (Which button to hit should be shown on the POST screen.) I know nothing about the Foxconn BIOS structure but somewhere the connected drives are listed.
    Are you sure? I cannot remember seeing a "Pilot Light" on my comps.
    Are you referring to the Monitor?
    Do you have any noises when you push the start button? Fans? POST?
    It could just be your start button gone south.
  5. 2017/08/31
    Soloist
    Thanks for reply, no output from pc to screen, key do not wkg so del not applicable. hd does not run, no fans. It seems that the PSU is waiting for a reply fm the mobo.
  6. 2017/08/31
    Soloist
    Thanks for your reply. No noises, no fans, no monitor output of course, just a tiny light on the front of the pc to show that power is supplied.
  7. 2017/08/31
    Christer
    If you have changed the power supply and verified that it's working, then with no POST (Power On Self Test) it seems like the motherboard is dead. The backup battery on the motherboard, if "empty" would not prevent the motherboard from working, just prevent it from keeping the settings.
    Soloist likes this.
  8. 2017/08/31
    Soloist
    Christer, thank you, I like your conclusions and agree. I'll let you know the outcome.
    Regards, Soloist.
  9. 2017/08/31
    Have you checked your ATX connector on the Motherboard? Is it clean and making good contact? Any sign of burning on these contacts? Is it 20 pin or 24 pin? Does it have a separate 4/8 pin board connector?
