Password Problems
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by ROBINT, 2005/04/07.
  1. 2005/04/07
    ROBINT
    ROBINT Inactive Thread Starter
    I have two systems, both identicle with respect to Netscape 7.2.
    I use the same name (janedoe@netscape.net) on both machines. as a secondary Email service.
    Obviously I use the same password also......One system is a laptop
    used when on the road. For no apparent reason the laptop gives me an error.
    "Name and/or password incorrect or Invalid "...I Have to my knowledge changed nothing.......I did download and review Netscape 8 (beta) but promptly removed it..........Any help please......RTM :confused:
  2. 2005/04/08
    Ramona
    Ramona Geek Member Alumni
    Robin,
    On the laptop, go to Edit | Preferences | Privacy & Security | Passwords
    Click on the "Manage Stored Passwords" tab
    Delete the Mail Password
    Close Netscape
    Now Start Netscape Mail & Newsgroups, and enter your Password again. Did you get an error?
    A few questions:
    When you uninstalled Netscape 8, did you do so using Add/Remove?
    Did you uninstall Netscape 7.2 before installing Netscape 8, or did you run them both?
    Did you share the Profile with the two browsers?
    Ramona
    ROBINT
    password errors
    I removed all passwords ref to rtmillsm
    Restarted NS Same error?????????
    I uninstalled using Add/Remove protocal.
    I did not uninstall NS7 Prior.
    I did share profile..
    Hope yu can assist I'm Stumped..TNXS RTM
  5. 2005/04/08
    Westside
    Westside Inactive Alumni
    " did not uninstall NS7 Prior. I did share profile.." with what?
    This makes it very confusing now. But if you mean 7.2 and 8, it does not apply. They can't share profiles, although NS8 can use 7.2 settings, I suppose.
    Are accessing Webmail at the website, or are you trying to access it in 7.2 mail.
    If you stored the password, you view it in the Privacy, etc. If you did not store, and you tried Webmail site as well as Netscape mail, and get the same results....
  6. 2005/04/08
    ROBINT
    password
    The creation of the confusion is named "GRANDSON" who was threatened with leg and other parts possibly being removed. The laptop was at his disposal without permission....Hence a new (his) password had been entered.
    All has been corrected...Sorry for loss of your valuable time..TNXS RTM
  7. 2005/04/08
    Ramona
    Robin,
    Thanks for letting us know! I have two of those mentioned little men, and understand perfectly.
    It is never a waste of time... ;)
    Ramona
