paint file dropdown box does not work
Discussion in 'Legacy Windows' started by Thomas Nunn, 2003/06/01.
  1. 2003/06/01
    Thomas Nunn
    Thomas Nunn Inactive Thread Starter
    please help me the file drop down box on paint will not work
    this is a frequent problem that has gotten very irritating i downloaded the fix that is suppose to fix the office conflict
    i reloaded windows and it did not help
    any help out there quailfarther@yahoo.com;)
  2. 2003/06/02
    Lonny Jones
    Lonny Jones Inactive Alumni
    Hi Thomas
    What versio( flavor) of windows
    and what office program are you taling about , what fix also ?
    You are talking about microsoft paint right?
    You could try uninstalling paint and reinstalling
    Go into control panel addremove programs -windows setup
    in there I think its under accessories, uncheck it click apply then OK go back and add it. though if youve reloaded windows this might not work either..let us know.
    Lonny
    Thomas Nunn
    this is ms paint on windows 98
    i tried the uninstall and reinstall to no avail
    this problem started when i treid to edit the 3d maze screen saver
    it worked for a while
    the office program i use is office 2000
    i downloaded a "fix" and it put a mfc42.dll on my screensaver along with a msvcrt.dll and Olepro3.dll file they are on my desktop and im suppose to copy them to the system files but dont know where to put them
    the problem is all the dropdown boxes work EXCEPT the "file "
    it just prompt me to go to "help "
    the fix refered to a conflict with office 97 and not 2000 so it might not apply.
  5. 2003/06/02
    Lonny Jones
  6. 2003/06/03
    Thomas Nunn
    worked for a while
    i read a mfc42.dll error on neo napster when i donwnlaoded the file to fix paint.... a mfc42.dll file the neo napster stopped opening when i fixed the napster the paint problem came back...so i suspect it is a problem with the mfc42.dll or the filters..the bug appears on paint when you past a jpg of gif pictuce to paint....
    i will go to the sites you listed and look around
  7. 2003/06/03
    Thomas Nunn
    all of my efforts have yeilded me a partial fix
    here is the latest symptoms
    when i open paint the file dropdown box does NOT open
    if i paste a bmp file in then it will open
    if i paste in anything other than a bmp the file dropdowns will NOT open
    i downloaded a mfc42.dll an msvcrt.dll and an olepro3 that are supposed to help but i dont know how to copy them to the system files...they are on the desktop...reinstalling paint from the win 98 se disk did not work i have a win 98 original disk that 98se disabled the 98se uninstaler has been removed... i redownloaded the paint 95 from microsoft and the bug reapeared....maybe if i installled another paint like program....
  8. 2003/06/03
    KevinSaul
    KevinSaul Inactive
    Right click on My Computer and select Explore.
    On the left side of the screen
    Click on the + sign next to drive C:
    Click on the + sign next to Windows
    Click on the System folder
    Locate the 3 files on the right side of the screen and rename them to something like 'oldmsvcrt.dll', this way you just have to rename them again if you find you need them.
    Click on Desktop (left side of the screen).
    On the Right side of the screen, while holding the ctrl key down, click on the 3 files you want to move and drag them to the System folder on the left side.
