Pagefile on drive other than C:
Discussion in 'Windows XP' started by tnf150boy, 2003/03/10.
  1. 2003/03/10
    tnf150boy
    tnf150boy Inactive Thread Starter
    Hi all. I've read/heard that placing the WinXP (or Win2K) pagefile on a non-system drive (drives X: or V: in my case) is better/more efficient than having it on the system drive (C: ). Assuming that is true (please tell me if it isn't), is it better to put the pagefile on a drive slaved to the system drive or to a drive on the secondary IDE, or does it matter? I have 3 hard drives on my pc, one (X: ) slaved to the system drive (C: ) and the other (V: ) as master on the secondary IDE (all via a PCI IDE controller). Also, would it add anything to have 2 pagefiles, one on the C: drive and the 2nd on one of the other drives? If you can also give me a quick-n-dirty explanation re: why it's better for the pagefile to be on a non-system drive, it would be greatly appreciated. :p :D :cool:
  2. 2003/03/10
    Bmoore1129
    Bmoore1129 Geek Member
    Hey tnf150boy
    I have page file on my second physical HD on the first partition (F). The first partition on a HD is the fastest. So if you see any increase of speed that would be the best place to put it. I also have it set for minimum of 100 Meg and no maximum.
    To tell the truth, I can't see a bit of difference in speed but then I don't do games or CAD or Video. The only reason I keep it there is so the pagefile doesn't get fragmented and scattered throughout my OS and visa versa.
    Do a search on this BBS for "Pagefile" and get probably more than you wanted to know about the subject. Many opinions also.;)
    I agree with Bill
    On my system (Win XP Pro) I have a dedicated 2GB partition on the primary hard drive for a fixed size pagefile, !.5 x RAM plus a bit. Advantage is that the pagefile does not get fragmented and. if using Photoshop a fixed pagefile on another drive/partition is strongly reccommended.
    Don't know about multiple pagefiles - suggest they would confuse Win :confused: ?
  5. 2003/03/10
    Abraxas
    Abraxas Inactive
    Agree with these guys, especially about having the pagefile in its own partition near the beginning of the drive. That reduces fragmentation and maximizes speed.
    I have 3 pagefiles, one within the first gig of the system HD, one within the system partition since debugging cannot occur without a pagefile in the system partition, and a 3rd at the beginning of the faster second HD. The algorithm that XP uses ensures that the fastest pagefile is used to maximum first.
    These articles are not specifically XP related and the size recommendations vary, but they are instructive:
    http://support.microsoft.com/default.aspx?scid=kb;en-us;99768
    http://support.microsoft.com/default.aspx?scid=kb;en-us;197379
    Many people with a large amount of RAM suggest eliminating the pagefile altogether.
  6. 2003/03/10
    Bmoore1129
    Yes, I turned the pagefile off and everything except my scanner worked just fine. The scanner needs a pagefile for some reason.
  7. 2003/03/11
    tnf150boy
    Awesome, thanks for the info!
  8. 2003/03/11
    Barbara-Ann
    Barbara-Ann Inactive
    Christer
    Christer Geek Member Staff
    I have read the articles to which links were posted and as usual, it generated a question or two:
    I plan(ned) on moving the pagefile to my D: (when I migrate to XP) with nothing on C: in order to make the system partition as small as possible for imaging using Ghost.
    I´ve come across two reasons to leave a small bit on C:. The first reason being that under certain circumstances the system would need a place to make a dump.
    The question is, would I need this dump if I don´t even know what to do with it?
    It could get quite large if it´s supposed to take care of a full RAM dump.
    The second reason is that the OS might create a big pagefile on C: if all of it is moved to a different partition. A small bit on C: would prevent that. Has anyone had this experience?
    Thanks in advance,
    Christer
  10. 2003/03/16
    Abraxas
    Abraxas Inactive
    The pagefile will stay where you put it if it is large enough. The system will indeed create one on the system partition if it needs to, but it is certainly not automatic.
    The memory dump has been turned off on my machine because it is not very helpful from my point of view. It can be turned back on for trouble-shooting any time you want, so I personally agree with you that it is not of much use for the most part. And if your system is not experiencing a lot of errors, there won't be any.
    The files are the size of RAM. They can certainly use a lot of space if frequent, but can be easily deleted.
  11. 2003/03/16
    Christer
    Abraxas,
    thanks for Your reply!
    I´ll go by my plan #1 then!
    Do I need to turn off the memory dump and if "yes ", where do I do it?
    Do these files have the *.dmp extension?
    Christer
  12. 2003/03/16
    Abraxas
    Abraxas Inactive
    Yes, they are the dmp's.
    Right-click My Computer, Properties, Advanced, Startup and Recovery settings. The only things you really should have (unless you were on a network in which case the Admin Alert may be useful) in the System Failure section is "Write an event to the log ". The dump can be set to "None" and the "automatically Restart" turned off so in the event of an error, you will get a bluescreen with error information instead of an automatic restart.
    I think these are more informative, and it removes the possibility of constant restarts in a loop if , for example, the error occurred on shutdown.
    Just my opinion but as you can see, I'm still running :D .
  13. 2003/03/17
    Christer
    Abraxas,
    I´ve just adopted Your opinion as my own and added Your configuration to my list of "what to do when I finally migrate to XP "!
    Thanks,
    Christer :)
  14. 2003/03/17
    rambler
    rambler Inactive
    If you have a single HD, the best place for the pagefile is on the system partition. Putting it on another partition will degrade access times as the HD head has to move further to access it. If you're running out of space on the system partiition moving the pagefile to another partition is a quick and easy way of freeing up some space however.
    With more than one HD, the best place is on a different HD. It doesn't matter whether it's on a primary or secondary partition in this case. There's no reason why you shouldn't have more than one pagefile, as Abraxas says, Windows will favour the faster HD anyway.
    I don't know where Bmoore1129 got his information that a primary partition is any "faster" than any other - they're on the same HD.
  15. 2003/03/17
    Bmoore1129
    Rambler
    Don't believe I said anything about a primary partition. I said the first partition on a physical drive.
    Here is one of the many places you can find opinions on hard drive architecture and operation.
  16. 2003/03/17
    Christer
    Someone on the Windows BBS said that the heads on the HDD are put in random idling positions in order not to get excessive wear of the disks in one position. This would mean that accesstime for the pagefile wouldn´t be affected too much by placing it at the approximate center of a 40 GB HDD.
    As much as everyone is very nice and helpful ...... :) ...... different opinions can be confusing ...... :confused: ...... especially for someone like me who believes in everyone ......:D !
    Christer
  17. 2003/03/17
    Abraxas
    Abraxas Inactive
    I have one page file in a 1 gig partition at the beginning of my system drive. Rotational speed and access is faster on the outer edge (which is why Windows puts things on the disk from the outside inward).
    I also disagree about the disadvantages of having a pagefile in a separate partition on the same drive as the system drive. It is true that there is increased head movement in accessing the pagefile if it is in a different partition, but whether there is actually significantly more than there would be with the pagefile being fragmented in the system partition is debatable. But though a close call, the advantage of not having to defragment the pagefile, the pagefile's not fragmenting the system partition when changing size, and the absence of a pagefile on the system partition for ghosting operations, all make it preferable to me.
    Having the pagefile in a small, separate partition at the beginning of the drive also makes it contiguous to the system files (which is not the case if the pagefile is on a partition after the system partition). This really keeps head movement to a minimum.
    In addition, my separated pagefiles are on FAT16 partitions, which have faster access times than either FAT32 or NTFS volumes.
    Christer---
    Hopefully, we aren't getting you too confused. Page and swap file threads always generate a number of theories, and I have certainly subscribed to all of them at one time or the other.
    But, I think most people would agree that the differences in the different configurations is slight. It may well be that the only noticeable, practical difference you would see is in fragmentation rates. Any reasonable choice on your part will work out fine.
    A couple other things you may want to tweak after you install: temp internet files and restore space.
    In the System section on My Computer Properties, System Restore tab, you can highlight a drive and change the settings for how much space to reserve for SR. I have mine set to 2% of the drive which gives me 10-12 50-meg restore points. I can't imagine needing more than that and the default setting will fill your drive with restore points.
    The default on the size of the Temporary Internet Files is equally outrageous. People recommend anything from 2-80 megs, but not the humongous amount Windows assigns.
    No matter how big a drive you have, there's no sense in filling it with unneeded junk. It slows things down.
  18. 2003/03/17
    Christer
    I have come to the conclusion that if opinions on a matter differ, then it´s not important to go either way but if a piece of advice is more or less unanimous, then it´s more important to go by it.
    I´ve picked up Your advice about the sizes of the System Restore and the TIF-folder.
    I´ve shut off SR altogether and rely on Norton Ghost.
    I probably was the laughing-stock when we discussed the size of my WinME installation and I revealed a whopping 1.5 GB in my TIF-folder ...... :D ...... it´s now down at 50 MB ...... :cool:
    I wonder though why Microsoft would decide on a default setting that actually might cause problems, such as the huge TIF-folder slowing down the browser?!
  19. 2003/03/17
    Abraxas
    Abraxas Inactive
    I've wondered about that, too. Generally the defaults are an average of the optimal settings for a large number of different machines. The TIF and Sys Restore settings seem so ridiculous that I am left puzzled, like you. No idea, but I am sure that these things are too big. How long would it take to load a web page if IE had to search a gig for the preloaded page? A long time, anyway.
    I suppose it could be a simple mistake, but it is hard to imagine that something that big could be missed.
  20. 2003/03/18
    Christer
    Now we are heading for lingual confusion since my PC speaks swedish:
    My browser, IE6SP1, has in Tools / Internet Options / Temporary Internet Files - Settings, four radio buttons to control how stored webpages are updated.
    1) Every time a webpage is visited, 2) Everytime IE is started, 3) Automatic or 4) Never.
    My browser is set to "Automatic" which, according to my understanding of the help-text is the most efficient option.
    I also conclude that with all of these settings, apart from #4, only a small cache is needed if most of it gets updated anyway.
    #2 must be a real resource hog and #4, well, is anyone using it to manually update every revisited webpage?
    It seems to me like any setting that is changed, prompts further considerations and tweaking ...... :eek: ...... will we ever be able to fully optimize our systems?
    Christer
  21. 2003/03/18
    Abraxas
    Abraxas Inactive
    The only setting besides Automatic that I have used for any time is the one which allows refreshing of pages once per IE session. That certaily makes pages load faster after the first visit.
    The only problem with that setting is pages containing real-time data. But for those few, the Refresh button takes care of that.
