Overlibs do not work in IE 10
Discussion in 'Internet Explorer & Microsoft Edge' started by alanrf, 2013/04/01.
  1. 2013/04/01
    alanrf
    alanrf Well-Known Member Thread Starter
    If you use a site that makes use of the overlib feature you may find that the overlibs no longer function.
    There is no local fix possible but the website should be able to fix this issue easily. Until then, of course, you can use the 'compatibility' mode.
    Basically, overlib recognises all versions of IE up to v9 but then falls over when it hits a double digit version.
    If it affects you and if you have access to the relevant file the following link should help you resolve any issues.
    http://www.prasanthkumars.com/myblog.asp
