Outlook Rule Problem
Discussion in 'General Internet' started by ebbourg, 2002/07/01.
  1. 2002/07/01
    ebbourg
    ebbourg Inactive Thread Starter
    OS= WinMe Outlook2K2XP I recently tried using the mail rule "stop processing all following rules ". I then noticed that my rules weren't working so I removed this rule. Now, my rules still aren't working. Am I going to have to remove all rules and start from scratch?
    ED
  2. 2002/07/01
    Panda Lifetime Subscription
    Panda Inactive
    I use win98 and OE5.5, so am not sure how this will work with your versions, but how many rules do you have going? Is one of the rules loaded down with lots of addresses? Like maybe one rule has a bunch of addresses listed as spam and go into the spam folder? Or maybe the addresses are being blocked? The reason I ask is, I had the same exact problem once with mine. I had over 200 messages in a BLOCKED SENDER rule and all of a sudden my regular mail was going into the trash on it's own (the blocked sender rule puts that address in the trash automatically)! I ended up having to undo every address in the blocked sender rule list and then my mail behaved as it should again. You may have to do this to get your mail to accept your rules. It's just a thought.
    Let us know if this worked for you.
