OutLook Express; Strange fonts
Discussion in 'Internet Explorer & Microsoft Edge' started by DaveMo, 2003/03/12.
  1. 2003/03/12
    DaveMo
    DaveMo Inactive Thread Starter
    Need some ideas about this one. Some emails I recieve contained a form of scrambled text. It has occured in both text and HTML fomats. It's like it is written in a font I do not have. Most of the email is readable, just a line or two comes out in this strange format. An example is included below:
    "The 5-11, 180-pound goaltender has posted 30-or-more wins in seven of his last nine NHL seasons, posting a career best 39-6-5 record, along with 2.17 goals against average during the 1995-96 season. The two-time Stanley Cup winner, backstopped the Red Wings to the 1997-98 Championship, recording a 16-6 record, along with a 2.12 goals against average. He set a Red Wing record by recording a 21-game unbeaten streak (19-0-2) and notched a career-best, 13-game winning streak during the 1995-96 season. Osgood has earned the Jennings Trophy on two occasions (1996-97, 1995-96), along with teammates Mike Vernon and Kevin Hodson.
    \ ´ à ð d ç翿Àmxø æ¿¿ ÿÿÿÿ-Ãô Vn¯ mÀl@m m% _ô|Ù?æ¿¿[ pæ¿¿t濿ÿÿÿÿ "i?æ¿¿C?  ?æ¿¿4g 1?A? 'Àæ¿¿ÃS '?  =d¶ òb =d¶ üæ¿¿+¨ üæ¿¿G äæ¿¿ÃŒÃ¦¿¿Ã¹9Ü翿Üæ¿¿ º üæ¿¿x  ,ç¿¿p ,ç¿¿d  Ü뿿÷ =-n>
  2. 2003/03/12
    jmatt
    jmatt Well-Known Member
    1st step .
    Online Virus check ( free )
    http://housecall.antivirus.com/
    http://www.coledata.com/virusalert.htm
    http://www.cybertechhelp.com/html/misc/av.php
    http://www.pandasoftware.es/activescan/activescan-com.asp
    Next , try choice 2 .
    http://www.windows-help.net/windows98/ie50-11.shtml
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;q194177
    W95 you have 3 choices . With W98 , if you have IE5.1 or higher & you
    still have IE4 installed the following applies . No IE4 only 2 choices .
    IE5.5 if over the top of 5.1 , offers 3 choices .
    You can install IE5.1 straight over 4 . A big feature with IE5 is that
    it can be repaired without uninstalling . Here is how to do it . Open
    Control Panel , Add / Remove , click on Microsoft Internet Explorer ,
    then click on add / remove down the bottom . This opens a window with
    3 choices .
    Choice 1. Add , insert your IE5 install program & you can find other
    items you may not have installed 1st time .
    Choice 2. Repair , fixes problems that may crop up with IE5 / Outlook
    Choice 3. If unfixable , removes IE5 & goes back to IE4 , now if you
    want to you can reinstall IE5 or a later version or another browser
    altogether .
    No Microsoft Internet Explorer in Control Panel !
    Start > Run , key in msinfo32 and press Enter . Click on Tools > IE Repair Tool or Start >
    Programs > Accessories > System Tools > System Information . Click on Tools > IE Repair Tool .
    Internet Explorer Repair tool from a command prompt:
    Click Start , and then click Run .
    In the Open box, type the following command, and then click OK :
    rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
    NOTE : This command is case sensitive.
    W2000 > Start > Run
    then enter exactly (copy & paste)
    rundll32.exe setupwbv.dll,IE5Maintenance
    this will give you the IE Repair dialog... proceed to repair IE
    Repair IE6
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;q318378
    http://www.3dspotlight.com/tweaks/ie6/index.shtml
    http://www.winguides.com/registry/display.php/442/
