Outlook Express Send Problem
Discussion in 'Windows XP' started by hawkeye, 2007/02/03.
  1. 2007/02/03
    hawkeye
    hawkeye Inactive Thread Starter
    When I create an email and click send Outlook Express will either give me a rejection for an invalid email address (which it is not) and/or take an unusually long time to send the message. Previously, (about a week ago it would send quickly) now it goes to my outbox and either gets rejected and/or take several minutes to send the message. I have checked mmy account (2) settings and deleted several .dbx files that were quite large. Your suggestions for resolution of this problem will be appreciated.
  2. 2007/02/03
    surferdude2
    surferdude2 Inactive
    It may be your ISP's mail server instead of something in your software. Give them a call and see how good their support is. ;)
    If they aren't having any problems then you can uninstall and reinstall OE. It's in the Windows Components of add/remove programs.
    hawkeye
    Thanks for your reply, removal and reinstall is my last option.
    I have been in touch with tech support and they helped check my settings for the two accounts I have.
    I suspect anti virus and have just turned off the mail monitoring in avast and need to run some trials. I am receiving mail very fast and mailwasher is working fine for incoming mail. I also have to check spyware blaster and Search and destroy to see if either is causing the problem.
    Then comes Outlook Express removal and reinstall.
  5. 2007/02/04
    hawkeye
    Called ISP tech support again today and they admitted to having email problems. They have now recovered and mail send is much better today althoulgh not as good as I remember in the past. Think I will do nothing further on this situation. Thanks for your suggestions and help
  6. 2007/02/04
    surferdude2
    And the beat goes on... often the problem isn't from within but from without and when it comes to problems, I prefer mine to be without. ;)
    Thanks for the feedback hawkeye.
