Outlook Express 6 problems
Discussion in 'Internet Explorer & Microsoft Edge' started by RSchu, 2002/06/06.
  1. 2002/06/06
    RSchu
    RSchu Inactive Thread Starter
    :( Just recently when using outlook express 6 I have found that when I click on a web address in an email they will not load. They used to but... any ideas about this?
    Thanks!
  2. 2002/06/06
    brett
    brett Inactive Alumni
    This should help.
    Welcome to the boards :)
    RSchu
    This would not load...
    Sorry Brett... but your this should help didn't load so I can't get at the this. Aparently it is also affecting Explorer 6. Can you just post the address and I will copy it and past it in the address window on explorer to load it. Thanks!
  5. 2002/06/06
    brett
  6. 2002/06/06
    brett
    Also, you're not running any type of popup stopper, are you?
  7. 2002/06/09
    RSchu
    PopStopper
    Yes I was however they are all deleted. Now a couple of other questions...
    1. In the files you gave me I believe it was Q316527 it instructs you to go to the hidden files and find Urlmon.dll and open it ... well I do not have that dll in my System 32 file. I guess I need to get it?
    2. When I restart my computer I always get a error that states you are missing a critical file MSSWS.dll Where does one get this file? I have looked and can't even figure what program it is suppose to be with. Any ideas?
    Thanks!
  8. 2002/06/09
    brett
    Are you sure that it isn't in C:\WINDOWS\SYSTEM rather than C:\WINDOWS\SYSTEM32 (use Find Files/Folders to look)? It's possible that you didn't see it because Hidden and System files are (by default) not displayed when you look in a folder.
    If it's not there, send me your e-mail address and I'll mail a copy to you.
    I have no idea what this file is. I can only assume that an application which runs at startup is trying to call on it. I have, however, discovered a download source for this file:-
    http://comm2.eiinc.com/download/ServicePacks/sp1 Exchange 2000/setup/i386/search/
    You could try placing it in C:\WINDOWS\SYSTEM.
  9. 2002/06/09
    Miz
    Miz Inactive Alumni
    Miz,
    #8
