outlook asking for dial up connection
Discussion in 'General Internet' started by mjbennet, 2003/02/07.
  1. 2003/02/07
    mjbennet
    mjbennet Inactive Thread Starter
    after i have collected my email and gone off line, if i open an email with a link, i always get the dial up connection box asking me to connect. i find this v. irritating, how can i stop this?
  2. 2003/02/07
    aleekat
    aleekat Inactive
    In IE, tools, options, connections. "Never dial" setting.
    Zander
    Zander Geek Member Alumni
    By going offline do you mean you just disconnect your dialup connection or do you disconnect and then go offline in OE? By this i mean, after you've disconnected your connection, in OE you should also click on file\work offline. If you do this it shouldn't try to dial up.
