Outlook 2003 problems after HD upgrade
Discussion in 'Microsoft Mail (Outlook / OE / Windows Mail)' started by cbernad, 2005/08/24.
  1. 2005/08/24
    cbernad
    cbernad Inactive Thread Starter
    I ran out of space on my old HD, so I put a new Seagate in and used their software to copy everything over to the new HD and I'm now using the new HD only. Everything SEEMS OK, but Outlook 2003 is doing something weird with my downloaded e-mails. When you "send/recieve" it goes through everything just fine and although I don't see it downloading any messages (i.e. it doesn't say "downloading message x of x "), I can go to my on-line e-mail view and see that messages that were there before syncing are not there now. And, I can see where it does put Junk Mail messages in the Junk Mail folder. But I can not find the new e-mails anywhere. I've already lost a days worth of e-mails.
    I tried doing a reinstall of Office 2003, but it says that there is a file missing and the installer will not load. Any thoughts on what file(s) may not have been copied over and what to do?
    Thx
  2. 2005/08/24
    What OS are you running?
    You might also want to turn on logging while you are chasing this gremlin. Tools~options~other~advanced options button~logging
