Resolved Outlook 2003 [Problem with Forwarding messages]
Discussion in 'Microsoft Mail (Outlook / OE / Windows Mail)' started by Jacobowicz, 2011/02/12.
  1. 2011/02/12
    Jacobowicz
    Jacobowicz Inactive Thread Starter
    I use Outlook 2003 but I have a wee problem when fowarding e-mails to others.....
    When I decide to FORWARD to others and click onto the Send / Receive button, the ribbon on the bottom right hand side says it is complete even though it has NOT been sent.
    Currently the way I get around this problem is to drop the message, say into "junk mail" and then click send so as to place into the outbox once again and then click send /recieve once again and then it is sent.
    Any ideas as to why this should happen and how may I overcome this problem.
    Only serious suggestions please!!:confused:
  2. 2011/02/12
    Does this happen with any or all emails?
    Do you get any sort of error message when you try to forward?
    Jacobowicz
    Steve, this only happens when I forward e-mails to many or just one.
    I do not get any error message and as I stated in my post it just shows completed.
  5. 2011/02/13
    How large is the PST file?
    If your pst file is close to 2gigs in size AND it was upgraded from an earlier version - that can and will cause all sorts of weird problems.
  6. 2011/02/13
    Jacobowicz
    I am a thicko and gereatric taboo!!!!
    What is a ST file?
    Lawrie:confused:
  7. 2011/02/13
    The PST file is the file that holds all of your emails/contacts/calendar entries.
    In XP - it is located here: C:\Documents and Settings\Your User Name\Local Settings\Application Data\Microsoft\Outlook
  8. 2011/02/13
    Jacobowicz
    Thank you for your response.
    You suggested C:\Documents and Settings\Your User Name\Local Settings\Application Data\Microsoft\Outlook
    Unfortunately I can only get as far as my name and do not have Local Settings shown after my name. All that I have shown is Desktop, Favourites, My Documents, Start Menu amd Start Windows.
    Where do I go from here?
  9. 2011/02/13
    You need to enable 'Show hidden files & folders .....
    Tools > Folder Options > View and check 'Show hidden files & folders'.
  10. 2011/02/13
    Jacobowicz
    I followed PeteC suggestions and was able to locate the files/folders suggested.
    The datfile was 1kb and the outlook office data file was 21,841kb.
    Does that help you any more
  11. 2011/02/13
    Jacobowicz
    See my response to Steve R Jones.
  12. 2011/02/14
    You need to find the PST file... By default - it will generally be called Outlook.pst .
  13. 2011/02/14
    Jacobowicz
    Steve think I sjall end this problem and live with what I have.
    Meanwhile thank you for everyt;)hing
