Resolved Outgoing Server Problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by derfsch, 2011/12/16.
  1. 2011/12/16
    derfsch
    derfsch Well-Known Member Thread Starter
    Hi All, ........... Recently I had occasion to switch from my Verizon mail account to Comcast and back again to Verizon. I reinstalled Thunderbird 8,0. There is no problems receiving mail but I cannot send any mail. I get the following mrssage:
    Sending of message failed.
    An error occurred sending mail: SMTP server smtp.verizon.net is unknown. The server may be incorrectly configured. Please verify etc. ...
    My outgoing server (SMTP) is showing as: user - smtp.verizon.net (Default) I have tried various changes in the server content to no avail. Does anyone have a solution to this problem.
  2. 2011/12/16
    wildfire
    wildfire Getting Old
    And with Verizon you can use 25 or 587 for the smtp port.
  5. 2011/12/17
    derfsch
    Wildfire, & TonyT, .............. I had used "outgoing.verizon.net" in one of my earlier attempts to solve my problem. Unfortunately I wasn't paying attention to the content of the the resulting Send Message Error screen, concentrating only on the "failure to send" words.
    The text of the Send Message Error screen:
    "Sending of message failed.
    An error occurred sending mail: Unable to establish a secure link with SMTP server
    outgoing.verizon.net using STARTTLS since it doesn't advertise that feature. Switch off STARTTLS for that server or contact your server provider."
    Once I followed the "Switch Off" instruction by bringing up the Outgoing Server (SMTP) screen, clicking the EDIT button and placing None in the Connection security block I was able to send my e-mail messages normally.
    As to the Verizon port, the Outgoing Server screen above shows that my system is using the 587 port.
    A Thank You to each of you for taking the time to suggest solutions to the Outgoing Server problem.
  6. 2011/12/17
    wildfire
    No problem and thank you for the update and resolution. Glad you got it sorted :)
