Optical Mouse setting and Netscape
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by vegaspat, 2005/02/09.
  1. 2005/02/09
    vegaspat
    vegaspat Well-Known Member Thread Starter
    I recently purchased an optical mouse and was going to utilize the different settings for the buttons. There is no help file or manual so of course I ran into a problem with setting one of the buttons.
    For the 4th button, I have several choices but can’t figure out how to set it at what I want. I selected the "Use Default Browser" and it keeps opening Netscape 4.7, which is NOT what I want. I rarely use that version. I normally alternate between Netscape 7.2 and FireFox.
    How in the world would I get one of those options if it were not on the drop down list in the mouse software? Is that some sort of Registry setting?
  2. 2005/02/09
    Ramona
    Ramona Geek Member Alumni
    VegasPat,
    Have you made Firefox your Default Browser? If not, you can do so here:
    Tools | Options | General, Default Browser.
    See if that opens Firefox, instead of Communicator. What is the Brand and model # of the optical mouse?
    Ramona
    vegaspat
    Ramona,
    Well, that kind of works. When I click the button now, FireFox opens but won't open my home page. (IWon.com) I get a time out message, but when I go to the Home icon on the Tool Bar, IWon opens up as usual.
    If I don't use the mouse and just open FireFox as I usually do, it loads my Home page just fine. Can't figure that one out.
    I also noticed today when sending an e-mail from a couple of sites, instead of the e-mail program from Netscape 7.2 opening, I get the Netscape 4.79 compose window. I never did before.
    I don't suppose this would have anything to do with all the Windows updates that I did today. Not my choice. (Microsoft)
    My new mouse is an Elements 4D Optical Mouse. I picked it up from my computer repair guy. The stuff is usually generic type stuff.
  5. 2005/02/09
    Ramona
    vegaspat,
    You need to ask your PC guy if he has a manual for the Mouse, or if he can get one for you.
    As to Communicator opening instead of 7.2, for your Mail, have you made 7.2 your default Mail program:
    Edit | Preferences | Mail & Newsgroups
    Use Netscape Mail as the default Mail Application.
    Sorry I can't be more helpful on your Mouse...
    Ramona
  6. 2005/02/10
    vegaspat
    Thanks. I appreciate your help.
    I suspect that there wouldn't be a manual. I was there when the PC guy opened the UPS box and pulled the mouse out. I guess they figure any nut could configure the mouse. Little do they know.
    What is your opinion on uninstalling 4.7? I kept it around because one of my bank sites would only recognize it and IE. I wrote to them twice and they said they would work on expanding the option. I recently saw where they now allow me to use both 7.2 and FireFox.
    Also, I know I must be nuts for sure. I have been trying to clear the location bar in FireFox and I'm sure I did it before. So far I haven't found the option. The help file doesn't tell me how.
