Windows Vista OMG Memory Issues
Discussion in 'Legacy Windows' started by bigtwenty, 2008/06/05.
  1. 2008/06/05
    bigtwenty
    bigtwenty Inactive Thread Starter
    I purchased 4 2GB sticks of memory. 2 for my laptop and 2 for another laptop. Only the first dumpis here due to posting space. I will post the others in other posts labeled: "OMG Memory issues ctd" so bear with me. Anyways, The first 3 dumps happened, then i decided to update my bios, to the latest bios. Then the 3rd dump happened, so i swapped memory between laptops because the other laptop hadnt crashed since that memory had been in there. So, the next two dumps happened. So, i am going to put the original memory in the laptop and try to get the money back. But i think before i do that, i am going to memtest this stuff. Oh yeah i think the first dmp was because i was using "switch" to convert an mp3, but the rest were happening just idle or surfing the web.
    Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
    Loading Dump File [c:\windows\minidump\Mini060208-01.dmp]
    Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
    Executable search path is: c:\windows\i386
    Windows Server 2008 Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 6001.18000.x86fre.longhorn_rtm.080118-1840
    Kernel base = 0x81c44000 PsLoadedModuleList = 0x81d5bc70
    Debug session time: Mon Jun 2 20:27:46.098 2008 (GMT-4)
    System Uptime: 0 days 0:50:10.058
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 1000008E, {c0000005, 81e6318c, 99aa7b2c, 0}
    Probably caused by : ntkrpamp.exe ( nt!ExpAllocateHandleTableEntry+4e )
    Followup: MachineOwner
    1: kd> !analyze -v;r;kv;lmtn;
    KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
    This is a very common bugcheck. Usually the exception address pinpoints
    the driver/function that caused the problem. Always note this address
    as well as the link date of the driver/image that contains this address.
    Some common problems are exception code 0x80000003. This means a hard
    coded breakpoint or assertion was hit, but this system was booted
    /NODEBUG. This is not supposed to happen as developers should never have
    hardcoded breakpoints in retail code, but ...
    If this happens, make sure a debugger gets connected, and the
    system is booted /DEBUG. This will let us see why this breakpoint is
    happening.
    Arguments:
    Arg1: c0000005, The exception code that was not handled
    Arg2: 81e6318c, The address that the exception occurred at
    Arg3: 99aa7b2c, Trap Frame
    Arg4: 00000000
    Debugging Details:
    EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
    FAULTING_IP:
    81e6318c 8b4004 mov eax,dword ptr [eax+4]
    TRAP_FRAME: 99aa7b2c -- (.trap 0xffffffff99aa7b2c)
    ErrCode = 00000000
    eax=00000000 ebx=001f0003 ecx=9d4fbe60 edx=84714bc0 esi=8515f418 edi=9d4fbe60
    eip=81e6318c esp=99aa7ba0 ebp=99aa7bb4 iopl=0 nv up ei pl zr na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
    nt!ExpAllocateHandleTableEntry+0x4e:
    81e6318c 8b4004 mov eax,dword ptr [eax+4] ds:0023:00000004=????????
    Resetting default scope
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
    BUGCHECK_STR: 0x8E
    PROCESS_NAME: SearchIndexer.e
    CURRENT_IRQL: 0
    LAST_CONTROL_TRANSFER: from 81e63252 to 81e6318c
    STACK_TEXT:
    99aa7bb4 81e63252 99aa7bd8 00100001 85d4cc08 nt!ExpAllocateHandleTableEntry+0x4e
    99aa7bd0 81e8b666 00000000 99aa7bfc 85d4ccac nt!ExCreateHandle+0x1b
    99aa7c30 81e621a8 00000000 84f1f488 9d4fbe60 nt!ObpCreateHandle+0x4f4
    99aa7c88 81e63ae7 068aa740 00000000 803d1101 nt!ObOpenObjectByName+0x2fa
    99aa7cfc 81e5453d 068aa764 00100001 068aa740 nt!IopCreateFile+0x63b
    99aa7d44 81c9ba7a 068aa764 00100001 068aa740 nt!NtOpenFile+0x2a
    99aa7d44 77929a94 068aa764 00100001 068aa740 nt!KiFastCallEntry+0x12a
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    068aa9dc 00000000 00000000 00000000 00000000 0x77929a94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: nt!ExpAllocateHandleTableEntry+4e
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: nt
    IMAGE_NAME: ntkrpamp.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 47918b12
    FAILURE_BUCKET_ID: 0x8E_nt!ExpAllocateHandleTableEntry+4e
    99aa7d44 77929a94 068aa764 00100001 068aa740 nt!KiFastCallEntry+0x12a (FPO: [0,3] TrapFrame @ 99aa7d64)
    start end module name
    80403000 8040b000 kdcom kdcom.dll Sat Jan 19 02:31:53 2008 (4791A769)
    8040b000 8046b000 mcupdate mcupdate.dll Sat Jan 19 02:29:43 2008 (4791A6E7)
    8046b000 8047c000 PSHED PSHED.dll Sat Jan 19 02:31:21 2008 (4791A749)
    8047c000 80484000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
    80484000 804c5000 CLFS CLFS.SYS Sat Jan 19 00:28:01 2008 (47918A61)
    804c5000 805a5000 CI CI.dll Fri Feb 22 00:00:56 2008 (47BE5708)
    805a5000 805d7000 fltmgr fltmgr.sys Sat Jan 19 00:28:10 2008 (47918A6A)
    805d7000 805e7000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
    80602000 8067e000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
    8067e000 8068b000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
    8068b000 806d1000 acpi acpi.sys Sat Jan 19 00:32:48 2008 (47918B80)
    806d1000 806da000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
    806da000 806e2000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
    806e2000 80709000 pci pci.sys Sat Jan 19 00:32:57 2008 (47918B89)
    80709000 80718000 partmgr partmgr.sys Sat Jan 19 00:49:54 2008 (47918F82)
    80718000 8071a900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8071b000 80725000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
    80725000 80734000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
    80734000 8077e000 volmgrx volmgrx.sys Sat Jan 19 00:50:00 2008 (47918F88)
    8077e000 80785000 intelide intelide.sys Sat Jan 19 00:49:42 2008 (47918F76)
    80785000 80793000 PCIIDEX PCIIDEX.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    80793000 807c0000 pcmcia pcmcia.sys Sat Jan 19 00:32:56 2008 (47918B88)
    807c0000 807d0000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
    807d0000 807d8000 atapi atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    807d8000 807f6000 ataport ataport.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    81c11000 81c44000 hal halmacpi.dll Sat Jan 19 00:27:20 2008 (47918A38)
    81c44000 81ffd000 nt ntkrpamp.exe Sat Jan 19 00:30:58 2008 (47918B12)
    82206000 82277000 ksecdd ksecdd.sys Sat Jan 19 00:41:20 2008 (47918D80)
    82277000 8228a000 DefragFS DefragFS.sys Wed Oct 03 13:01:59 2007 (4703CB07)
    8228a000 82395000 ndis ndis.sys Sat Jan 19 00:55:51 2008 (479190E7)
    82395000 823c0000 msrpc msrpc.sys Sat Jan 19 00:48:15 2008 (47918F1F)
    823c0000 823fa000 NETIO NETIO.SYS Sat Jan 19 00:56:19 2008 (47919103)
    8b202000 8b2e9000 tcpip tcpip.sys Sat Jan 19 00:56:48 2008 (47919120)
    8b2e9000 8b304000 fwpkclnt fwpkclnt.sys Sat Jan 19 00:55:44 2008 (479190E0)
    8b304000 8b313000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
    8b313000 8b351000 USBPORT USBPORT.SYS Sat Jan 19 00:53:23 2008 (47919053)
    8b351000 8b360000 usbehci usbehci.sys Sat Jan 19 00:53:21 2008 (47919051)
    8b360000 8b372000 HDAudBus HDAudBus.sys Tue Nov 27 18:18:41 2007 (474CA5D1)
    8b372000 8b3fb000 rdpdr rdpdr.sys Sat Jan 19 01:02:27 2008 (47919273)
    8b409000 8b518000 Ntfs Ntfs.sys Sat Jan 19 00:28:54 2008 (47918A96)
    8b518000 8b551000 volsnap volsnap.sys Sat Jan 19 00:50:10 2008 (47918F92)
    8b551000 8b559000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
    8b559000 8b568000 mup mup.sys Sat Jan 19 00:28:20 2008 (47918A74)
    8b568000 8b58f000 ecache ecache.sys Sat Jan 19 00:50:47 2008 (47918FB7)
    8b58f000 8b5a0000 disk disk.sys Sat Jan 19 00:49:47 2008 (47918F7B)
    8b5a0000 8b5c1000 CLASSPNP CLASSPNP.SYS Sat Jan 19 00:49:36 2008 (47918F70)
    8b5c1000 8b5ca000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
    8b5ca000 8b5e9000 mrxsmb mrxsmb.sys Sat Jan 19 00:28:33 2008 (47918A81)
    8b5ea000 8b5f5000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
    8b5f5000 8b5fe000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
    8f000000 8f00b000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
    8f00b000 8f74a300 nvlddmkm nvlddmkm.sys Fri Feb 22 09:52:02 2008 (47BEE192)
    8f74b000 8f7ea000 dxgkrnl dxgkrnl.sys Sat Jan 19 00:36:36 2008 (47918C64)
    8f7ea000 8f7f7000 watchdog watchdog.sys Sat Jan 19 00:35:29 2008 (47918C21)
    8f804000 8fa33000 NETw4v32 NETw4v32.sys Wed Sep 26 09:12:18 2007 (46FA5AB2)
    8fa33000 8fa62000 b57nd60x b57nd60x.sys Thu Feb 08 18:03:14 2007 (45CBAC32)
    8fa62000 8fa71200 ohci1394 ohci1394.sys Sat Jan 19 00:53:33 2008 (4791905D)
    8fa72000 8fa7f080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
    8fa80000 8fa93000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
    8fa93000 8fa9e000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8fa9e000 8faa9000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8faa9000 8fac3000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
    8fac3000 8facd000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
    8facd000 8fad0780 CmBatt CmBatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8fad1000 8fada000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8fada000 8fb08000 msiscsi msiscsi.sys Sat Jan 19 00:50:44 2008 (47918FB4)
    8fb08000 8fb49000 storport storport.sys Sat Jan 19 00:49:49 2008 (47918F7D)
    8fb49000 8fb54000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
    8fb54000 8fb6b000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
    8fb6b000 8fb76000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
    8fb76000 8fb99000 ndiswan ndiswan.sys Sat Jan 19 00:56:32 2008 (47919110)
    8fb99000 8fba8000 raspppoe raspppoe.sys Sat Jan 19 00:56:33 2008 (47919111)
    8fba8000 8fbbc000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
    8fbbc000 8fbd1000 rassstp rassstp.sys Sat Jan 19 00:56:43 2008 (4791911B)
    8fbd1000 8fbe1000 termdd termdd.sys Sat Jan 19 01:01:06 2008 (47919222)
    8fbe1000 8fbe2380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
    8fc0c000 8fc36000 ks ks.sys Sat Jan 19 00:49:21 2008 (47918F61)
    8fc36000 8fc44000 cledx cledx.sys Mon May 09 14:08:41 2005 (427FA729)
    8fc44000 8fc4e000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
    8fc4e000 8fc5b000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
    8fc5b000 8fc8f000 usbhub usbhub.sys Sat Jan 19 00:53:40 2008 (47919064)
    8fc8f000 8fca0000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
    8fca0000 8fcf5000 stwrt stwrt.sys Thu Sep 13 11:29:43 2007 (46E95767)
    8fcf5000 8fd22000 portcls portcls.sys Sat Jan 19 00:53:17 2008 (4791904D)
    8fd22000 8fd47000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
    8fd47000 8fd84000 HSXHWAZL HSXHWAZL.sys Thu Nov 02 22:42:16 2006 (454AAC88)
    8fd84000 8fda5000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
    8fda5000 8fdad000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
    8fdad000 8fdb8000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
    8fdb8000 8fdc6000 Npfs Npfs.SYS Sat Jan 19 00:28:09 2008 (47918A69)
    8fdc6000 8fdcf000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
    8fdcf000 8fde5000 tdx tdx.sys Sat Jan 19 00:55:58 2008 (479190EE)
    8fde5000 8fdf9000 smb smb.sys Sat Jan 19 00:55:27 2008 (479190CF)
    8fe00000 8fe08000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
    8fe09000 8ff0c000 HSX_DPV HSX_DPV.sys Thu Nov 02 22:43:26 2006 (454AACCE)
    8ff0c000 8ffc0000 HSX_CNXT HSX_CNXT.sys Thu Nov 02 22:42:05 2006 (454AAC7D)
    8ffc0000 8ffcd000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
    8ffcd000 8ffd3380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
    8ffd4000 8ffe0000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
    8ffe5000 8ffee000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
    8ffee000 8fff5000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
    8fff5000 8fffc000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
    90004000 9004c000 afd afd.sys Sat Jan 19 00:57:00 2008 (4791912C)
    9004c000 9007e000 netbt netbt.sys Sat Jan 19 00:55:33 2008 (479190D5)
    9007e000 90094000 pacer pacer.sys Sat Jan 19 00:55:53 2008 (479190E9)
    90094000 900a2000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
    900a2000 900b5000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
    900b5000 900bc760 SCDEmu SCDEmu.SYS Mon Aug 06 20:15:06 2007 (46B7B98A)
    900bd000 900f9000 rdbss rdbss.sys Sat Jan 19 00:28:34 2008 (47918A82)
    900f9000 90103000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
    90103000 9015d000 csc csc.sys Sat Jan 19 00:28:54 2008 (47918A96)
    9015d000 90174000 dfsc dfsc.sys Sat Jan 19 00:28:20 2008 (47918A74)
    90174000 90178c40 avgmfx86 avgmfx86.sys Thu Jan 10 12:05:15 2008 (4786504B)
    90179000 9018ef00 avgldx86 avgldx86.sys Thu Jan 31 12:38:23 2008 (47A2078F)
    9018f000 9019b000 usbccid usbccid.sys Sat Jan 19 00:49:30 2008 (47918F6A)
    9019b000 901a6000 SMCLIB SMCLIB.SYS Sat Jan 19 00:49:30 2008 (47918F6A)
    901a6000 901a7700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
    901a8000 901b5000 crashdmp crashdmp.sys Sat Jan 19 00:49:43 2008 (47918F77)
    901b5000 901c0000 dump_ataport dump_ataport.sys Sat Jan 19 00:49:40 2008 (47918F74)
    901c0000 901c8000 dump_atapi dump_atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    901c8000 901d2000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
    901d2000 901e1000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
    901e1000 901fc000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
    95e60000 96061000 win32k win32k.sys Thu Feb 28 23:21:37 2008 (47C78851)
    96080000 96089000 TSDDD TSDDD.dll Sat Jan 19 01:01:09 2008 (47919225)
    960a0000 960ae000 cdd cdd.dll Sat Jan 19 02:27:09 2008 (4791A64D)
    960b0000 960fc000 ATMFD ATMFD.DLL Sat Jan 19 00:36:13 2008 (47918C4D)
    9b60c000 9b6bb000 spsys spsys.sys Thu Jun 21 20:33:02 2007 (467B18BE)
    9b6bb000 9b6cb000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9b6cb000 9b6f5000 nwifi nwifi.sys Sat Jan 19 00:53:58 2008 (47919076)
    9b6f5000 9b6ff000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
    9b6ff000 9b712000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9b712000 9b77d000 HTTP HTTP.sys Sat Jan 19 00:55:21 2008 (479190C9)
    9b77d000 9b79a000 srvnet srvnet.sys Sat Jan 19 00:29:11 2008 (47918AA7)
    9b79a000 9b7b3000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
    9b7b3000 9b7c8000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
    9b7c8000 9b7e8000 mrxdav mrxdav.sys Sat Jan 19 00:28:44 2008 (47918A8C)
    9ca08000 9ca41000 mrxsmb10 mrxsmb10.sys Sat Jan 19 00:28:40 2008 (47918A88)
    9ca41000 9ca59000 mrxsmb20 mrxsmb20.sys Sat Jan 19 00:28:35 2008 (47918A83)
    9ca59000 9ca80000 srv2 srv2.sys Sat Jan 19 00:29:14 2008 (47918AAA)
    9ca80000 9cacc000 srv srv.sys Sat Jan 19 00:29:25 2008 (47918AB5)
    9cacc000 9cacf180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
    9cad0000 9cbae000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
    9cbae000 9cbd6000 fastfat fastfat.SYS Sat Jan 19 00:28:00 2008 (47918A60)
    9cbd6000 9cbe0000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
    9cbe0000 9cbec000 tcpipreg tcpipreg.sys Sat Jan 19 00:56:07 2008 (479190F7)
    9cbec000 9cbf4000 xaudio xaudio.sys Fri Aug 04 20:39:09 2006 (44D3E8AD)
    Unloaded modules:
    8fc00000 8fc08000 drmkaud.sys
    Checksum: 00000000
    8b5ca000 8b5d7000 crashdmp.sys
    Checksum: 00000000
    8b5d7000 8b5e2000 dump_ataport
    Checksum: 00000000
    8b5e2000 8b5ea000 dump_atapi.s
    Checksum: 00000000
    8fe00000 8fe09000 kbdhid.sys
    Checksum: 00000000
    8ffcd000 8ffe5000 cdrom.sys
    Checksum: 00000000
    :mad::confused::mad::confused::mad::confused::mad::confused:
  2. 2008/06/05
    bigtwenty
    (Continued) dmp 2 and 3
    Loading Dump File [c:\windows\minidump\Mini060408-01.dmp]
    Kernel base = 0x81c38000 PsLoadedModuleList = 0x81d4fc70
    Debug session time: Wed Jun 4 12:57:14.358 2008 (GMT-4)
    System Uptime: 0 days 4:03:40.391
    BugCheck 1A, {403, c002e7b8, 70955867, c002e5b8}
    Probably caused by : memory_corruption ( nt!MiDeletePte+1f5 )
    0: kd> !analyze -v;r;kv;lmtn;
    MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
    Arguments:
    Arg1: 00000403, The subtype of the bugcheck.
    Arg2: c002e7b8
    Arg3: 70955867
    Arg4: c002e5b8
    Debugging Details:
    BUGCHECK_STR: 0x1a_403
    PROCESS_NAME: avgscanx.exe
    CURRENT_IRQL: 2
    LAST_CONTROL_TRANSFER: from 81c763fd to 81c76ffc
    STACK_TEXT:
    8bfb5b88 81c763fd c002e7b8 8611f820 852e0db8 nt!MiDeletePte+0x1f5
    8bfb5cb4 81cca36e 05bb0000 05cf7fff ae240904 nt!MiDeleteVirtualAddresses+0x71e
    8bfb5d4c 81c8fa7a ffffffff 04afe9c8 04afe9bc nt!NtFreeVirtualMemory+0x652
    8bfb5d4c 77299a94 ffffffff 04afe9c8 04afe9bc nt!KiFastCallEntry+0x12a
    04afe914 00000000 00000000 00000000 00000000 0x77299a94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    nt!MiDeletePte+1f5
    81c76ffc 8b4d0c mov ecx,dword ptr [ebp+0Ch]
    SYMBOL_NAME: nt!MiDeletePte+1f5
    MODULE_NAME: nt
    IMAGE_NAME: memory_corruption
    FAILURE_BUCKET_ID: 0x1a_403_nt!MiDeletePte+1f5
    eax=81d30920 ebx=c002e7b8 ecx=81d381f8 edx=0000026a esi=81d3093c edi=8bfb57d8
    eip=81c76ffc esp=8bfb5b48 ebp=8bfb5b88 iopl=0 nv up ei pl nz na po nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000202
    nt!MiDeletePte+0x1f5:
    81c76ffc 8b4d0c mov ecx,dword ptr [ebp+0Ch] ss:0010:8bfb5b94=8611f820
    8bfb5d4c 77299a94 ffffffff 04afe9c8 04afe9bc nt!KiFastCallEntry+0x12a (FPO: [0,3] TrapFrame @ 8bfb5d64)
    80400000 80408000 kdcom kdcom.dll Sat Jan 19 02:31:53 2008 (4791A769)
    80408000 80468000 mcupdate mcupdate.dll Sat Jan 19 02:29:43 2008 (4791A6E7)
    80468000 80479000 PSHED PSHED.dll Sat Jan 19 02:31:21 2008 (4791A749)
    80479000 80481000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
    80481000 804c2000 CLFS CLFS.SYS Sat Jan 19 00:28:01 2008 (47918A61)
    804c2000 805a2000 CI CI.dll Fri Feb 22 00:00:56 2008 (47BE5708)
    805a2000 805d4000 fltmgr fltmgr.sys Sat Jan 19 00:28:10 2008 (47918A6A)
    805d4000 805e4000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
    80604000 80680000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
    80680000 8068d000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
    8068d000 806d3000 acpi acpi.sys Sat Jan 19 00:32:48 2008 (47918B80)
    806d3000 806dc000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
    806dc000 806e4000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
    806e4000 8070b000 pci pci.sys Sat Jan 19 00:32:57 2008 (47918B89)
    8070b000 8071a000 partmgr partmgr.sys Sat Jan 19 00:49:54 2008 (47918F82)
    8071a000 8071c900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8071d000 80727000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
    80727000 80736000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
    80736000 80780000 volmgrx volmgrx.sys Sat Jan 19 00:50:00 2008 (47918F88)
    80780000 80787000 intelide intelide.sys Sat Jan 19 00:49:42 2008 (47918F76)
    80787000 80795000 PCIIDEX PCIIDEX.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    80795000 807c2000 pcmcia pcmcia.sys Sat Jan 19 00:32:56 2008 (47918B88)
    807c2000 807d2000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
    807d2000 807da000 atapi atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    807da000 807f8000 ataport ataport.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    81c05000 81c38000 hal halmacpi.dll Sat Jan 19 00:27:20 2008 (47918A38)
    81c38000 81ff1000 nt ntkrpamp.exe Sat Jan 19 00:30:58 2008 (47918B12)
    82203000 82274000 ksecdd ksecdd.sys Sat Jan 19 00:41:20 2008 (47918D80)
    82274000 82287000 DefragFS DefragFS.sys Wed Oct 03 13:01:59 2007 (4703CB07)
    82287000 82392000 ndis ndis.sys Sat Jan 19 00:55:51 2008 (479190E7)
    82392000 823bd000 msrpc msrpc.sys Sat Jan 19 00:48:15 2008 (47918F1F)
    823bd000 823f7000 NETIO NETIO.SYS Sat Jan 19 00:56:19 2008 (47919103)
    8b20b000 8b2f2000 tcpip tcpip.sys Sat Jan 19 00:56:48 2008 (47919120)
    8b2f2000 8b30d000 fwpkclnt fwpkclnt.sys Sat Jan 19 00:55:44 2008 (479190E0)
    8b30d000 8b31c000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
    8b31c000 8b35a000 USBPORT USBPORT.SYS Sat Jan 19 00:53:23 2008 (47919053)
    8b35a000 8b369000 usbehci usbehci.sys Sat Jan 19 00:53:21 2008 (47919051)
    8b369000 8b37b000 HDAudBus HDAudBus.sys Tue Nov 27 18:18:41 2007 (474CA5D1)
    8b37b000 8b3b8000 HSXHWAZL HSXHWAZL.sys Thu Nov 02 22:42:16 2006 (454AAC88)
    8b3b8000 8b3ce000 tdx tdx.sys Sat Jan 19 00:55:58 2008 (479190EE)
    8b3ce000 8b3e2000 smb smb.sys Sat Jan 19 00:55:27 2008 (479190CF)
    8b3e2000 8b3fd000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
    8b408000 8b517000 Ntfs Ntfs.sys Sat Jan 19 00:28:54 2008 (47918A96)
    8b517000 8b550000 volsnap volsnap.sys Sat Jan 19 00:50:10 2008 (47918F92)
    8b550000 8b558000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
    8b558000 8b567000 mup mup.sys Sat Jan 19 00:28:20 2008 (47918A74)
    8b567000 8b58e000 ecache ecache.sys Sat Jan 19 00:50:47 2008 (47918FB7)
    8b58e000 8b59f000 disk disk.sys Sat Jan 19 00:49:47 2008 (47918F7B)
    8b59f000 8b5c0000 CLASSPNP CLASSPNP.SYS Sat Jan 19 00:49:36 2008 (47918F70)
    8b5c0000 8b5c9000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
    8b5c9000 8b5d3000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
    8b5d3000 8b5e2000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
    8b5e9000 8b5f4000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
    8b5f4000 8b5fd000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
    8ee00000 8ee0b000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
    8ee0c000 8f54b300 nvlddmkm nvlddmkm.sys Fri Feb 22 09:52:02 2008 (47BEE192)
    8f54c000 8f5eb000 dxgkrnl dxgkrnl.sys Sat Jan 19 00:36:36 2008 (47918C64)
    8f5eb000 8f5f8000 watchdog watchdog.sys Sat Jan 19 00:35:29 2008 (47918C21)
    8f604000 8f833000 NETw4v32 NETw4v32.sys Wed Sep 26 09:12:18 2007 (46FA5AB2)
    8f833000 8f862000 b57nd60x b57nd60x.sys Thu Feb 08 18:03:14 2007 (45CBAC32)
    8f862000 8f871200 ohci1394 ohci1394.sys Sat Jan 19 00:53:33 2008 (4791905D)
    8f872000 8f87f080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
    8f880000 8f893000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
    8f893000 8f89e000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8f89e000 8f8a9000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8f8a9000 8f8c3000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
    8f8c3000 8f8cd000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
    8f8cd000 8f8d0780 CmBatt CmBatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8f8d1000 8f8da000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8f8da000 8f908000 msiscsi msiscsi.sys Sat Jan 19 00:50:44 2008 (47918FB4)
    8f908000 8f949000 storport storport.sys Sat Jan 19 00:49:49 2008 (47918F7D)
    8f949000 8f954000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
    8f954000 8f96b000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
    8f96b000 8f976000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
    8f976000 8f999000 ndiswan ndiswan.sys Sat Jan 19 00:56:32 2008 (47919110)
    8f999000 8f9a8000 raspppoe raspppoe.sys Sat Jan 19 00:56:33 2008 (47919111)
    8f9a8000 8f9bc000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
    8f9bc000 8f9d1000 rassstp rassstp.sys Sat Jan 19 00:56:43 2008 (4791911B)
    8f9d1000 8f9f2000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
    8f9f2000 8f9fd000 dump_ataport dump_ataport.sys Sat Jan 19 00:49:40 2008 (47918F74)
    8fc03000 8fc8c000 rdpdr rdpdr.sys Sat Jan 19 01:02:27 2008 (47919273)
    8fc8c000 8fc9c000 termdd termdd.sys Sat Jan 19 01:01:06 2008 (47919222)
    8fc9c000 8fc9d380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
    8fc9e000 8fcc8000 ks ks.sys Sat Jan 19 00:49:21 2008 (47918F61)
    8fcc8000 8fcd6000 cledx cledx.sys Mon May 09 14:08:41 2005 (427FA729)
    8fcd6000 8fce0000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
    8fce0000 8fced000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
    8fced000 8fd21000 usbhub usbhub.sys Sat Jan 19 00:53:40 2008 (47919064)
    8fd21000 8fd32000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
    8fd32000 8fd87000 stwrt stwrt.sys Thu Sep 13 11:29:43 2007 (46E95767)
    8fd87000 8fdb4000 portcls portcls.sys Sat Jan 19 00:53:17 2008 (4791904D)
    8fdb4000 8fdd9000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
    8fdd9000 8fde5000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
    8fde5000 8fdf0000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
    8fdf0000 8fdfe000 Npfs Npfs.SYS Sat Jan 19 00:28:09 2008 (47918A69)
    8fe00000 8fe07000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
    8fe07000 8fe0f000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
    8fe0f000 8ff12000 HSX_DPV HSX_DPV.sys Thu Nov 02 22:43:26 2006 (454AACCE)
    8ff12000 8ffc6000 HSX_CNXT HSX_CNXT.sys Thu Nov 02 22:42:05 2006 (454AAC7D)
    8ffc6000 8ffd3000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
    8ffd3000 8ffdc000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
    8ffdc000 8ffe2380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
    8ffe3000 8ffeb000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
    8ffeb000 8fff4000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
    8fff4000 8fffb000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
    90005000 9004d000 afd afd.sys Sat Jan 19 00:57:00 2008 (4791912C)
    9004d000 9007f000 netbt netbt.sys Sat Jan 19 00:55:33 2008 (479190D5)
    9007f000 90095000 pacer pacer.sys Sat Jan 19 00:55:53 2008 (479190E9)
    90095000 900a3000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
    900a3000 900b6000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
    900b6000 900bd760 SCDEmu SCDEmu.SYS Mon Aug 06 20:15:06 2007 (46B7B98A)
    900be000 900fa000 rdbss rdbss.sys Sat Jan 19 00:28:34 2008 (47918A82)
    900fa000 90104000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
    90104000 9015e000 csc csc.sys Sat Jan 19 00:28:54 2008 (47918A96)
    9015e000 90175000 dfsc dfsc.sys Sat Jan 19 00:28:20 2008 (47918A74)
    90175000 90179c40 avgmfx86 avgmfx86.sys Thu Jan 10 12:05:15 2008 (4786504B)
    9017a000 9018ff00 avgldx86 avgldx86.sys Thu Jan 31 12:38:23 2008 (47A2078F)
    90190000 901a7000 usbccgp usbccgp.sys Sat Jan 19 00:53:29 2008 (47919059)
    901a7000 901a8700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
    901a9000 901b2000 hidusb hidusb.sys Sat Jan 19 00:53:17 2008 (4791904D)
    901b2000 901c2000 HIDCLASS HIDCLASS.SYS Sat Jan 19 00:53:16 2008 (4791904C)
    901c2000 901cb000 kbdhid kbdhid.sys Sat Jan 19 00:49:17 2008 (47918F5D)
    901cb000 901d3000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
    901d3000 901df000 usbccid usbccid.sys Sat Jan 19 00:49:30 2008 (47918F6A)
    901df000 901ea000 SMCLIB SMCLIB.SYS Sat Jan 19 00:49:30 2008 (47918F6A)
    901ea000 901f7000 crashdmp crashdmp.sys Sat Jan 19 00:49:43 2008 (47918F77)
    901f7000 901ff000 dump_atapi dump_atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    95e10000 96011000 win32k win32k.sys Thu Feb 28 23:21:37 2008 (47C78851)
    96030000 96039000 TSDDD TSDDD.dll Sat Jan 19 01:01:09 2008 (47919225)
    96050000 9605e000 cdd cdd.dll Sat Jan 19 02:27:09 2008 (4791A64D)
    96060000 960ac000 ATMFD ATMFD.DLL Sat Jan 19 00:36:13 2008 (47918C4D)
    9b80f000 9b8be000 spsys spsys.sys Thu Jun 21 20:33:02 2007 (467B18BE)
    9b8be000 9b8ce000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9b8ce000 9b8f8000 nwifi nwifi.sys Sat Jan 19 00:53:58 2008 (47919076)
    9b8f8000 9b902000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
    9b902000 9b915000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9b915000 9b980000 HTTP HTTP.sys Sat Jan 19 00:55:21 2008 (479190C9)
    9b980000 9b99d000 srvnet srvnet.sys Sat Jan 19 00:29:11 2008 (47918AA7)
    9b99d000 9b9b6000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
    9b9b6000 9b9cb000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
    9b9cb000 9b9eb000 mrxdav mrxdav.sys Sat Jan 19 00:28:44 2008 (47918A8C)
    9b9eb000 9b9f7000 tcpipreg tcpipreg.sys Sat Jan 19 00:56:07 2008 (479190F7)
    9c800000 9c80a000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
    9c80b000 9c82a000 mrxsmb mrxsmb.sys Sat Jan 19 00:28:33 2008 (47918A81)
    9c82a000 9c863000 mrxsmb10 mrxsmb10.sys Sat Jan 19 00:28:40 2008 (47918A88)
    9c863000 9c87b000 mrxsmb20 mrxsmb20.sys Sat Jan 19 00:28:35 2008 (47918A83)
    9c87b000 9c8a2000 srv2 srv2.sys Sat Jan 19 00:29:14 2008 (47918AAA)
    9c8a2000 9c8ee000 srv srv.sys Sat Jan 19 00:29:25 2008 (47918AB5)
    9c8ee000 9c916000 fastfat fastfat.SYS Sat Jan 19 00:28:00 2008 (47918A60)
    9c916000 9c919180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
    9c91a000 9c9f8000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
    9c9f8000 9ca00000 xaudio xaudio.sys Fri Aug 04 20:39:09 2006 (44D3E8AD)
    Unloaded modules:
    8f5f8000 8f600000 drmkaud.sys
    Checksum: 00000000
    8b5c9000 8b5d6000 crashdmp.sys
    Checksum: 00000000
    8b5d6000 8b5e1000 dump_ataport
    Checksum: 00000000
    8b5e1000 8b5e9000 dump_atapi.s
    Checksum: 00000000
    8ffd3000 8ffdc000 kbdhid.sys
    Checksum: 00000000
    8ffd3000 8ffeb000 cdrom.sys
    Checksum: 00000000
    Loading Dump File [c:\windows\minidump\Mini060408-02.dmp]
    Kernel base = 0x81c34000 PsLoadedModuleList = 0x81d4bc70
    Debug session time: Wed Jun 4 16:47:10.878 2008 (GMT-4)
    System Uptime: 0 days 2:34:30.836
    BugCheck 100000D1, {38c2040, 1b, 0, 0}
    Probably caused by : ntkrpamp.exe ( nt!ExFreePoolWithTag+573 )
    DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If kernel debugger is available get stack backtrace.
    Arguments:
    Arg1: 038c2040, memory referenced
    Arg2: 0000001b, IRQL
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: 00000000, address which referenced memory
    Debugging Details:
    READ_ADDRESS: GetPointerFromAddress: unable to read from 81d6b868
    Unable to read MiSystemVaType memory at 81d4b420
    038c2040
    CURRENT_IRQL: 1b
    FAULTING_IP:
    +0
    00000000 ?? ???
    CUSTOMER_CRASH_COUNT: 2
    BUGCHECK_STR: 0xD1
    LAST_CONTROL_TRANSFER: from 81c446ef to 81d22401
    STACK_TEXT:
    880bf8d8 81c446ef b89c3760 81f303b8 00000000 nt!ExFreePoolWithTag+0x573
    880bf970 81e4ced4 00000000 00000000 879fb970 nt!VfAvlLookupTreeNode+0x78
    880bf988 81e4cf50 b89c3768 00000000 dafe4be8 nt!ObpWaitForMultipleObjects+0x256
    880bfbfc 81e4cc43 00000013 00000001 00000000 nt!ObpWaitForMultipleObjects+0x2c8
    880bfd48 81c8ba7a 00000013 08c5d5d0 00000001 nt!NtWaitForMultipleObjects+0xcc
    880bfd48 76f79a94 00000013 08c5d5d0 00000001 nt!KiFastCallEntry+0x12a
    0e8cf95c 00000000 00000000 00000000 00000000 0x76f79a94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    81d22401 8b4704 mov eax,dword ptr [edi+4]
    SYMBOL_NAME: nt!ExFreePoolWithTag+573
    MODULE_NAME: nt
    FAILURE_BUCKET_ID: 0xD1_nt!ExFreePoolWithTag+573
    eax=81d22401 ebx=880bf800 ecx=00000000 edx=880bf8bc esi=00000000 edi=880bf8bc
    eip=81d22401 esp=880bf8cc ebp=000000e1 iopl=0 nv up di pl nz na po nc
    cs=0d00 ss=0010 ds=bba3 es=f8bc fs=8c8e gs=0000 efl=00000000
    nt!ExFreePoolWithTag+0x573:
    81d22401 8b4704 mov eax,dword ptr [edi+4] ds:bba3:880bf8c0=81d22401
    880bfd48 76f79a94 00000013 08c5d5d0 00000001 nt!KiFastCallEntry+0x12a (FPO: [0,3] TrapFrame @ 880bfd64)
    80409000 80411000 kdcom kdcom.dll Sat Jan 19 02:31:53 2008 (4791A769)
    80411000 80471000 mcupdate mcupdate.dll Sat Jan 19 02:29:43 2008 (4791A6E7)
    80471000 80482000 PSHED PSHED.dll Sat Jan 19 02:31:21 2008 (4791A749)
    80482000 8048a000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
    8048a000 804cb000 CLFS CLFS.SYS Sat Jan 19 00:28:01 2008 (47918A61)
    804cb000 805ab000 CI CI.dll Fri Feb 22 00:00:56 2008 (47BE5708)
    805ab000 805dd000 fltmgr fltmgr.sys Sat Jan 19 00:28:10 2008 (47918A6A)
    805dd000 805ed000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
    805ed000 805fd000 termdd termdd.sys Sat Jan 19 01:01:06 2008 (47919222)
    80607000 80683000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
    80683000 80690000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
    80690000 806d6000 acpi acpi.sys Sat Jan 19 00:32:48 2008 (47918B80)
    806d6000 806df000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
    806df000 806e7000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
    806e7000 8070e000 pci pci.sys Sat Jan 19 00:32:57 2008 (47918B89)
    8070e000 8071d000 partmgr partmgr.sys Sat Jan 19 00:49:54 2008 (47918F82)
    8071d000 8071f900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    80720000 8072a000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
    8072a000 80739000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
    80739000 80783000 volmgrx volmgrx.sys Sat Jan 19 00:50:00 2008 (47918F88)
    80783000 8078a000 intelide intelide.sys Sat Jan 19 00:49:42 2008 (47918F76)
    8078a000 80798000 PCIIDEX PCIIDEX.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    80798000 807c5000 pcmcia pcmcia.sys Sat Jan 19 00:32:56 2008 (47918B88)
    807c5000 807d5000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
    807d5000 807dd000 atapi atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    807dd000 807fb000 ataport ataport.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    81c01000 81c34000 hal halmacpi.dll Sat Jan 19 00:27:20 2008 (47918A38)
    81c34000 81fed000 nt ntkrpamp.exe Sat Jan 19 00:30:58 2008 (47918B12)
    82205000 82276000 ksecdd ksecdd.sys Sat Jan 19 00:41:20 2008 (47918D80)
    82276000 82289000 DefragFS DefragFS.sys Wed Oct 03 13:01:59 2007 (4703CB07)
    82289000 82394000 ndis ndis.sys Sat Jan 19 00:55:51 2008 (479190E7)
    82394000 823bf000 msrpc msrpc.sys Sat Jan 19 00:48:15 2008 (47918F1F)
    823bf000 823f9000 NETIO NETIO.SYS Sat Jan 19 00:56:19 2008 (47919103)
    84800000 848e7000 tcpip tcpip.sys Sat Jan 19 00:56:48 2008 (47919120)
    848e7000 84902000 fwpkclnt fwpkclnt.sys Sat Jan 19 00:55:44 2008 (479190E0)
    84902000 84911000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
    84911000 8494f000 USBPORT USBPORT.SYS Sat Jan 19 00:53:23 2008 (47919053)
    8494f000 8495e000 usbehci usbehci.sys Sat Jan 19 00:53:21 2008 (47919051)
    8495e000 84970000 HDAudBus HDAudBus.sys Tue Nov 27 18:18:41 2007 (474CA5D1)
    84970000 849f9000 rdpdr rdpdr.sys Sat Jan 19 01:02:27 2008 (47919273)
    84a00000 84a09000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
    84a0f000 84b1e000 Ntfs Ntfs.sys Sat Jan 19 00:28:54 2008 (47918A96)
    84b1e000 84b57000 volsnap volsnap.sys Sat Jan 19 00:50:10 2008 (47918F92)
    84b57000 84b5f000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
    84b5f000 84b6e000 mup mup.sys Sat Jan 19 00:28:20 2008 (47918A74)
    84b6e000 84b95000 ecache ecache.sys Sat Jan 19 00:50:47 2008 (47918FB7)
    84b95000 84ba6000 disk disk.sys Sat Jan 19 00:49:47 2008 (47918F7B)
    84ba6000 84bc7000 CLASSPNP CLASSPNP.SYS Sat Jan 19 00:49:36 2008 (47918F70)
    84bc7000 84bd0000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
    84bd0000 84be6000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
    84bf0000 84bfb000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
    8b004000 8b743300 nvlddmkm nvlddmkm.sys Fri Feb 22 09:52:02 2008 (47BEE192)
    8b744000 8b7e3000 dxgkrnl dxgkrnl.sys Sat Jan 19 00:36:36 2008 (47918C64)
    8b7e3000 8b7f0000 watchdog watchdog.sys Sat Jan 19 00:35:29 2008 (47918C21)
    8b7f0000 8b7fb000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
    8b80f000 8ba3e000 NETw4v32 NETw4v32.sys Wed Sep 26 09:12:18 2007 (46FA5AB2)
    8ba3e000 8ba6d000 b57nd60x b57nd60x.sys Thu Feb 08 18:03:14 2007 (45CBAC32)
    8ba6d000 8ba7c200 ohci1394 ohci1394.sys Sat Jan 19 00:53:33 2008 (4791905D)
    8ba7d000 8ba8a080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
    8ba8b000 8ba9e000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
    8ba9e000 8baa9000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8baa9000 8bab4000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8bab4000 8bace000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
    8bace000 8bad8000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
    8bad8000 8baf0000 cdrom cdrom.sys Sat Jan 19 00:49:50 2008 (47918F7E)
    8baf0000 8baf3780 CmBatt CmBatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8baf4000 8bafd000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8bafd000 8bb2b000 msiscsi msiscsi.sys Sat Jan 19 00:50:44 2008 (47918FB4)
    8bb2b000 8bb6c000 storport storport.sys Sat Jan 19 00:49:49 2008 (47918F7D)
    8bb6c000 8bb77000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
    8bb77000 8bb8e000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
    8bb8e000 8bb99000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
    8bb99000 8bbbc000 ndiswan ndiswan.sys Sat Jan 19 00:56:32 2008 (47919110)
    8bbbc000 8bbcb000 raspppoe raspppoe.sys Sat Jan 19 00:56:33 2008 (47919111)
    8bbcb000 8bbdf000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
    8bbdf000 8bbf4000 rassstp rassstp.sys Sat Jan 19 00:56:43 2008 (4791911B)
    8bbf4000 8bbf5380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
    8bc07000 8bc31000 ks ks.sys Sat Jan 19 00:49:21 2008 (47918F61)
    8bc31000 8bc3f000 cledx cledx.sys Mon May 09 14:08:41 2005 (427FA729)
    8bc3f000 8bc49000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
    8bc49000 8bc56000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
    8bc56000 8bc8a000 usbhub usbhub.sys Sat Jan 19 00:53:40 2008 (47919064)
    8bc8a000 8bc9b000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
    8bc9b000 8bcf0000 stwrt stwrt.sys Thu Sep 13 11:29:43 2007 (46E95767)
    8bcf0000 8bd1d000 portcls portcls.sys Sat Jan 19 00:53:17 2008 (4791904D)
    8bd1d000 8bd42000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
    8bd42000 8bd7f000 HSXHWAZL HSXHWAZL.sys Thu Nov 02 22:42:16 2006 (454AAC88)
    8bd7f000 8bda0000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
    8bda0000 8bda8000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
    8bda8000 8bdb3000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
    8bdb3000 8bdc1000 Npfs Npfs.SYS Sat Jan 19 00:28:09 2008 (47918A69)
    8bdc1000 8bdca000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
    8bdca000 8bde0000 tdx tdx.sys Sat Jan 19 00:55:58 2008 (479190EE)
    8bde0000 8bdf4000 smb smb.sys Sat Jan 19 00:55:27 2008 (479190CF)
    8d803000 8d906000 HSX_DPV HSX_DPV.sys Thu Nov 02 22:43:26 2006 (454AACCE)
    8d906000 8d9ba000 HSX_CNXT HSX_CNXT.sys Thu Nov 02 22:42:05 2006 (454AAC7D)
    8d9ba000 8d9c7000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
    8d9c7000 8d9d0000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
    8d9d0000 8d9d7000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
    8d9d7000 8d9de000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
    8d9de000 8d9e6000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
    8d9e7000 8d9ed380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
    8d9ee000 8d9fa000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
    8de05000 8de4d000 afd afd.sys Sat Jan 19 00:57:00 2008 (4791912C)
    8de4d000 8de7f000 netbt netbt.sys Sat Jan 19 00:55:33 2008 (479190D5)
    8de7f000 8de95000 pacer pacer.sys Sat Jan 19 00:55:53 2008 (479190E9)
    8de95000 8dea3000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
    8dea3000 8deb6000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
    8deb6000 8debd760 SCDEmu SCDEmu.SYS Mon Aug 06 20:15:06 2007 (46B7B98A)
    8debe000 8defa000 rdbss rdbss.sys Sat Jan 19 00:28:34 2008 (47918A82)
    8defa000 8df04000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
    8df04000 8df5e000 csc csc.sys Sat Jan 19 00:28:54 2008 (47918A96)
    8df5e000 8df75000 dfsc dfsc.sys Sat Jan 19 00:28:20 2008 (47918A74)
    8df75000 8df79c40 avgmfx86 avgmfx86.sys Thu Jan 10 12:05:15 2008 (4786504B)
    8df7a000 8df8ff00 avgldx86 avgldx86.sys Thu Jan 31 12:38:23 2008 (47A2078F)
    8df90000 8df9c000 usbccid usbccid.sys Sat Jan 19 00:49:30 2008 (47918F6A)
    8df9c000 8dfa7000 SMCLIB SMCLIB.SYS Sat Jan 19 00:49:30 2008 (47918F6A)
    8dfa7000 8dfa8700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
    8dfa9000 8dfb6000 crashdmp crashdmp.sys Sat Jan 19 00:49:43 2008 (47918F77)
    8dfb6000 8dfc1000 dump_ataport dump_ataport.sys Sat Jan 19 00:49:40 2008 (47918F74)
    8dfc1000 8dfc9000 dump_atapi dump_atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    8dfc9000 8dfd3000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
    8dfd3000 8dfe2000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
    8dfe2000 8dffd000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
    940f0000 942f1000 win32k win32k.sys Thu Feb 28 23:21:37 2008 (47C78851)
    94310000 94319000 TSDDD TSDDD.dll Sat Jan 19 01:01:09 2008 (47919225)
    94330000 9433e000 cdd cdd.dll Sat Jan 19 02:27:09 2008 (4791A64D)
    94340000 9438c000 ATMFD ATMFD.DLL Sat Jan 19 00:36:13 2008 (47918C4D)
    9d601000 9d6b0000 spsys spsys.sys Thu Jun 21 20:33:02 2007 (467B18BE)
    9d6b0000 9d6c0000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9d6c0000 9d6ea000 nwifi nwifi.sys Sat Jan 19 00:53:58 2008 (47919076)
    9d6ea000 9d6f4000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
    9d6f4000 9d707000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9d707000 9d772000 HTTP HTTP.sys Sat Jan 19 00:55:21 2008 (479190C9)
    9d772000 9d78f000 srvnet srvnet.sys Sat Jan 19 00:29:11 2008 (47918AA7)
    9d78f000 9d7a8000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
    9d7a8000 9d7bd000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
    9d7bd000 9d7dd000 mrxdav mrxdav.sys Sat Jan 19 00:28:44 2008 (47918A8C)
    9d7dd000 9d7fc000 mrxsmb mrxsmb.sys Sat Jan 19 00:28:33 2008 (47918A81)
    9ec01000 9ec3a000 mrxsmb10 mrxsmb10.sys Sat Jan 19 00:28:40 2008 (47918A88)
    9ec3a000 9ec52000 mrxsmb20 mrxsmb20.sys Sat Jan 19 00:28:35 2008 (47918A83)
    9ec52000 9ec79000 srv2 srv2.sys Sat Jan 19 00:29:14 2008 (47918AAA)
    9ec79000 9ecc5000 srv srv.sys Sat Jan 19 00:29:25 2008 (47918AB5)
    9ecc5000 9eced000 fastfat fastfat.SYS Sat Jan 19 00:28:00 2008 (47918A60)
    9eced000 9ecf0180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
    9ecf1000 9edcf000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
    9edcf000 9edd9000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
    9edd9000 9ede5000 tcpipreg tcpipreg.sys Sat Jan 19 00:56:07 2008 (479190F7)
    9ede5000 9eded000 xaudio xaudio.sys Fri Aug 04 20:39:09 2006 (44D3E8AD)
    a980a000 a9821000 usbccgp usbccgp.sys Sat Jan 19 00:53:29 2008 (47919059)
    a9821000 a982a000 hidusb hidusb.sys Sat Jan 19 00:53:17 2008 (4791904D)
    a982a000 a983a000 HIDCLASS HIDCLASS.SYS Sat Jan 19 00:53:16 2008 (4791904C)
    a983a000 a9843000 kbdhid kbdhid.sys Sat Jan 19 00:49:17 2008 (47918F5D)
    a9843000 a984b000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
    Unloaded modules:
    a984b000 a9851000 UnlockerDriv
    Checksum: 00000000
    8bdf4000 8bdfc000 drmkaud.sys
    Checksum: 00000000
    84bd0000 84bdd000 crashdmp.sys
    Checksum: 00000000
    84bdd000 84be8000 dump_ataport
    Checksum: 00000000
    84be8000 84bf0000 dump_atapi.s
    Checksum: 00000000
    8d9de000 8d9e7000 kbdhid.sys
    Checksum: 00000000
    bigtwenty
    dump 4
    Loading Dump File [c:\windows\minidump\Mini060508-01.dmp]
    Kernel base = 0x81c0e000 PsLoadedModuleList = 0x81d25c70
    Debug session time: Thu Jun 5 19:09:27.637 2008 (GMT-4)
    System Uptime: 0 days 10:18:17.503
    BugCheck C1, {fe3fefd0, fe3fe905, 2ba02f, 23}
    Unable to load image ATMFD.DLL, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for ATMFD.DLL
    *** ERROR: Module load completed but symbols could not be loaded for ATMFD.DLL
    Probably caused by : ATMFD.DLL ( ATMFD+142b5 )
    SPECIAL_POOL_DETECTED_MEMORY_CORRUPTION (c1)
    Special pool has detected memory corruption. Typically the current thread's
    stack backtrace will reveal the guilty party.
    Arguments:
    Arg1: fe3fefd0, address trying to free
    Arg2: fe3fe905, address where bits are corrupted
    Arg3: 002ba02f, (reserved)
    Arg4: 00000023, caller is freeing an address where nearby bytes within the same page have been corrupted
    Debugging Details:
    BUGCHECK_STR: 0xC1_23
    SPECIAL_POOL_CORRUPTION_TYPE: 23
    PROCESS_NAME: csrss.exe
    CURRENT_IRQL: 0
    LAST_CONTROL_TRANSFER: from 81ca5ab3 to 81cdb163
    STACK_TEXT:
    b82c372c 81ca5ab3 000000c1 fe3fefd0 fe3fe905 nt!KeBugCheckEx+0x1e
    b82c3824 81cfbf78 fe3fefd0 fb316cb0 fe3fefd0 nt!MmFreeSpecialPool+0x6c
    b82c388c 9441aa09 fe3fefd0 00000000 fe3fefe0 nt!ExFreePoolWithTag+0xeb
    b82c38a0 944d42b5 fe3fefe0 2c639522 fb316cb0 win32k!VerifierEngFreeMem+0x4b
    b82c38d4 944d2c60 fe3fefe8 2c6394fe fb316cb0 ATMFD+0x142b5
    b82c3908 944d0906 2c6394aa 00500000 fc05ecf8 ATMFD+0x12c60
    b82c395c 944d3828 2c63947a 00000000 000000cc ATMFD+0x10906
    b82c398c 944d3901 2c639436 00000000 00000000 ATMFD+0x13828
    b82c39c0 944d4271 00000001 00000001 65626441 ATMFD+0x13901
    b82c39d4 944d4371 000000cc 00000001 2c6397e6 ATMFD+0x14271
    b82c3a10 944d2b40 00000000 000000cc 2c6397a6 ATMFD+0x14371
    b82c3a50 944c3fb7 ffffffff b82c3b04 00000000 ATMFD+0x12b40
    b82c3aa4 942da2bf fac6caf0 ff4cfcf0 00000001 ATMFD+0x3fb7
    b82c3ad4 942b3ad7 fac6caf0 ff4cfcf0 00000001 win32k!PDEVOBJ::QueryFontData+0x3c
    b82c3b48 942b40e5 00000002 00000000 b82c3cdc win32k!RFONTOBJ::bInitCache+0xc9
    b82c3bf4 94350028 b82c3cf4 b82c3c98 faceb12c win32k!RFONTOBJ::bRealizeFont+0x55f
    b82c3ca0 9434fd31 faceb008 00000000 00000002 win32k!RFONTOBJ::bInit+0x2dc
    b82c3cb8 942c9145 b82c3cf4 00000000 00000002 win32k!RFONTOBJ::vInit+0x16
    b82c3cd4 942c90bf ff4cfcf0 00000000 00000000 win32k!ulGetFontData2+0x17
    b82c3d00 942c92f2 99011fb1 00000000 00000000 win32k!ulGetFontData+0x48
    b82c3d48 81c65a7a 99011fb1 00000000 00000000 win32k!NtGdiGetFontData+0x2d
    b82c3d48 76ef9a94 99011fb1 00000000 00000000 nt!KiFastCallEntry+0x12a
    0012df14 00000000 00000000 00000000 00000000 0x76ef9a94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    ATMFD+142b5
    944d42b5 ?? ???
    SYMBOL_STACK_INDEX: 4
    SYMBOL_NAME: ATMFD+142b5
    MODULE_NAME: ATMFD
    IMAGE_NAME: ATMFD.DLL
    DEBUG_FLR_IMAGE_TIMESTAMP: 47918c4d
    FAILURE_BUCKET_ID: 0xC1_23_ATMFD+142b5
    eax=803d1120 ebx=fe3fe905 ecx=81d0e1f8 edx=0000011f esi=803d113c edi=b82c33a0
    eip=81cdb163 esp=b82c3710 ebp=b82c372c iopl=0 nv up ei pl nz ac po nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000212
    nt!KeBugCheckEx+0x1e:
    81cdb163 8be5 mov esp,ebp
    b82c38a0 944d42b5 fe3fefe0 2c639522 fb316cb0 win32k!VerifierEngFreeMem+0x4b (FPO: [Non-Fpo])
    b82c3ad4 942b3ad7 fac6caf0 ff4cfcf0 00000001 win32k!PDEVOBJ::QueryFontData+0x3c (FPO: [Non-Fpo])
    b82c3b48 942b40e5 00000002 00000000 b82c3cdc win32k!RFONTOBJ::bInitCache+0xc9 (FPO: [Non-Fpo])
    b82c3bf4 94350028 b82c3cf4 b82c3c98 faceb12c win32k!RFONTOBJ::bRealizeFont+0x55f (FPO: [Non-Fpo])
    b82c3ca0 9434fd31 faceb008 00000000 00000002 win32k!RFONTOBJ::bInit+0x2dc (FPO: [Non-Fpo])
    b82c3cb8 942c9145 b82c3cf4 00000000 00000002 win32k!RFONTOBJ::vInit+0x16 (FPO: [Non-Fpo])
    b82c3cd4 942c90bf ff4cfcf0 00000000 00000000 win32k!ulGetFontData2+0x17 (FPO: [Non-Fpo])
    b82c3d00 942c92f2 99011fb1 00000000 00000000 win32k!ulGetFontData+0x48 (FPO: [Non-Fpo])
    80401000 80409000 kdcom kdcom.dll Sat Jan 19 02:31:53 2008 (4791A769)
    80409000 80469000 mcupdate mcupdate.dll Sat Jan 19 02:29:43 2008 (4791A6E7)
    80469000 8047a000 PSHED PSHED.dll Sat Jan 19 02:31:21 2008 (4791A749)
    8047a000 80482000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
    80482000 804c3000 CLFS CLFS.SYS Sat Jan 19 00:28:01 2008 (47918A61)
    804c3000 805a3000 CI CI.dll Fri Feb 22 00:00:56 2008 (47BE5708)
    805a3000 805c1000 ataport ataport.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    805c1000 805f3000 fltmgr fltmgr.sys Sat Jan 19 00:28:10 2008 (47918A6A)
    8060d000 80689000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
    80689000 80696000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
    80696000 806dc000 acpi acpi.sys Sat Jan 19 00:32:48 2008 (47918B80)
    806dc000 806e5000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
    806e5000 806ed000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
    806ed000 80714000 pci pci.sys Sat Jan 19 00:32:57 2008 (47918B89)
    80714000 80723000 partmgr partmgr.sys Sat Jan 19 00:49:54 2008 (47918F82)
    80723000 80725900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    80726000 80730000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
    80730000 8073f000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
    8073f000 80789000 volmgrx volmgrx.sys Sat Jan 19 00:50:00 2008 (47918F88)
    80789000 80790000 intelide intelide.sys Sat Jan 19 00:49:42 2008 (47918F76)
    80790000 8079e000 PCIIDEX PCIIDEX.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    8079e000 807cb000 pcmcia pcmcia.sys Sat Jan 19 00:32:56 2008 (47918B88)
    807cb000 807db000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
    807db000 807e3000 atapi atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    807e3000 807f3000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
    81c0e000 81fc7000 nt ntkrpamp.exe Sat Jan 19 00:30:58 2008 (47918B12)
    81fc7000 81ffa000 hal halmacpi.dll Sat Jan 19 00:27:20 2008 (47918A38)
    82202000 82273000 ksecdd ksecdd.sys Sat Jan 19 00:41:20 2008 (47918D80)
    82273000 82286000 DefragFS DefragFS.sys Wed Oct 03 13:01:59 2007 (4703CB07)
    82286000 82391000 ndis ndis.sys Sat Jan 19 00:55:51 2008 (479190E7)
    82391000 823bc000 msrpc msrpc.sys Sat Jan 19 00:48:15 2008 (47918F1F)
    823bc000 823f6000 NETIO NETIO.SYS Sat Jan 19 00:56:19 2008 (47919103)
    84808000 848ef000 tcpip tcpip.sys Sat Jan 19 00:56:48 2008 (47919120)
    848ef000 8490a000 fwpkclnt fwpkclnt.sys Sat Jan 19 00:55:44 2008 (479190E0)
    8490a000 84919000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
    84919000 84957000 USBPORT USBPORT.SYS Sat Jan 19 00:53:23 2008 (47919053)
    84957000 84966000 usbehci usbehci.sys Sat Jan 19 00:53:21 2008 (47919051)
    84966000 84978000 HDAudBus HDAudBus.sys Tue Nov 27 18:18:41 2007 (474CA5D1)
    84978000 849b5000 HSXHWAZL HSXHWAZL.sys Thu Nov 02 22:42:16 2006 (454AAC88)
    849b5000 849c3000 Npfs Npfs.SYS Sat Jan 19 00:28:09 2008 (47918A69)
    849c3000 849cc000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
    849cc000 849e2000 tdx tdx.sys Sat Jan 19 00:55:58 2008 (479190EE)
    849e2000 849f6000 smb smb.sys Sat Jan 19 00:55:27 2008 (479190CF)
    84a0d000 84b1c000 Ntfs Ntfs.sys Sat Jan 19 00:28:54 2008 (47918A96)
    84b1c000 84b55000 volsnap volsnap.sys Sat Jan 19 00:50:10 2008 (47918F92)
    84b55000 84b5d000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
    84b5d000 84b6c000 mup mup.sys Sat Jan 19 00:28:20 2008 (47918A74)
    84b6c000 84b93000 ecache ecache.sys Sat Jan 19 00:50:47 2008 (47918FB7)
    84b93000 84ba4000 disk disk.sys Sat Jan 19 00:49:47 2008 (47918F7B)
    84ba4000 84bc5000 CLASSPNP CLASSPNP.SYS Sat Jan 19 00:49:36 2008 (47918F70)
    84bc5000 84bce000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
    84bce000 84bd9000 dump_ataport dump_ataport.sys Sat Jan 19 00:49:40 2008 (47918F74)
    84bd9000 84be1000 dump_atapi dump_atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    84be1000 84beb000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
    84bee000 84bf9000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
    8ac06000 8b345300 nvlddmkm nvlddmkm.sys Fri Feb 22 09:52:02 2008 (47BEE192)
    8b346000 8b3e5000 dxgkrnl dxgkrnl.sys Sat Jan 19 00:36:36 2008 (47918C64)
    8b3e5000 8b3f2000 watchdog watchdog.sys Sat Jan 19 00:35:29 2008 (47918C21)
    8b3f2000 8b3fd000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
    8b406000 8b635000 NETw4v32 NETw4v32.sys Wed Sep 26 09:12:18 2007 (46FA5AB2)
    8b635000 8b664000 b57nd60x b57nd60x.sys Thu Feb 08 18:03:14 2007 (45CBAC32)
    8b664000 8b673200 ohci1394 ohci1394.sys Sat Jan 19 00:53:33 2008 (4791905D)
    8b674000 8b681080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
    8b682000 8b695000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
    8b695000 8b6a0000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8b6a0000 8b6ab000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8b6ab000 8b6c5000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
    8b6c5000 8b6cf000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
    8b6cf000 8b6e7000 cdrom cdrom.sys Sat Jan 19 00:49:50 2008 (47918F7E)
    8b6e7000 8b6ea780 CmBatt CmBatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8b6eb000 8b6f4000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8b6f4000 8b722000 msiscsi msiscsi.sys Sat Jan 19 00:50:44 2008 (47918FB4)
    8b722000 8b763000 storport storport.sys Sat Jan 19 00:49:49 2008 (47918F7D)
    8b763000 8b76e000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
    8b76e000 8b785000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
    8b785000 8b790000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
    8b790000 8b7b3000 ndiswan ndiswan.sys Sat Jan 19 00:56:32 2008 (47919110)
    8b7b3000 8b7c2000 raspppoe raspppoe.sys Sat Jan 19 00:56:33 2008 (47919111)
    8b7c2000 8b7d6000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
    8b7d6000 8b7eb000 rassstp rassstp.sys Sat Jan 19 00:56:43 2008 (4791911B)
    8b7eb000 8b7f3000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
    8b7f3000 8b7fe000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
    8bc06000 8bc8f000 rdpdr rdpdr.sys Sat Jan 19 01:02:27 2008 (47919273)
    8bc8f000 8bc9f000 termdd termdd.sys Sat Jan 19 01:01:06 2008 (47919222)
    8bc9f000 8bca0380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
    8bca1000 8bccb000 ks ks.sys Sat Jan 19 00:49:21 2008 (47918F61)
    8bccb000 8bcd9000 cledx cledx.sys Mon May 09 14:08:41 2005 (427FA729)
    8bcd9000 8bce3000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
    8bce3000 8bcf0000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
    8bcf0000 8bd24000 usbhub usbhub.sys Sat Jan 19 00:53:40 2008 (47919064)
    8bd24000 8bd35000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
    8bd35000 8bd8a000 stwrt stwrt.sys Thu Sep 13 11:29:43 2007 (46E95767)
    8bd8a000 8bdb7000 portcls portcls.sys Sat Jan 19 00:53:17 2008 (4791904D)
    8bdb7000 8bddc000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
    8bddc000 8bdfd000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
    8d805000 8d908000 HSX_DPV HSX_DPV.sys Thu Nov 02 22:43:26 2006 (454AACCE)
    8d908000 8d9bc000 HSX_CNXT HSX_CNXT.sys Thu Nov 02 22:42:05 2006 (454AAC7D)
    8d9bc000 8d9c9000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
    8d9c9000 8d9d2000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
    8d9d2000 8d9d9000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
    8d9d9000 8d9e0000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
    8d9e0000 8d9e8000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
    8d9e9000 8d9ef380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
    8d9f0000 8d9fc000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
    8da07000 8da4f000 afd afd.sys Sat Jan 19 00:57:00 2008 (4791912C)
    8da4f000 8da81000 netbt netbt.sys Sat Jan 19 00:55:33 2008 (479190D5)
    8da81000 8da97000 pacer pacer.sys Sat Jan 19 00:55:53 2008 (479190E9)
    8da97000 8daa5000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
    8daa5000 8dab8000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
    8dab8000 8dabf760 SCDEmu SCDEmu.SYS Mon Aug 06 20:15:06 2007 (46B7B98A)
    8dac0000 8dafc000 rdbss rdbss.sys Sat Jan 19 00:28:34 2008 (47918A82)
    8dafc000 8db06000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
    8db06000 8db60000 csc csc.sys Sat Jan 19 00:28:54 2008 (47918A96)
    8db60000 8db77000 dfsc dfsc.sys Sat Jan 19 00:28:20 2008 (47918A74)
    8db77000 8db7bc40 avgmfx86 avgmfx86.sys Thu Jan 10 12:05:15 2008 (4786504B)
    8db7c000 8db91f00 avgldx86 avgldx86.sys Thu Jan 31 12:38:23 2008 (47A2078F)
    8dba9000 8dbaa700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
    8dbcd000 8dbd9000 usbccid usbccid.sys Sat Jan 19 00:49:30 2008 (47918F6A)
    8dbd9000 8dbe4000 SMCLIB SMCLIB.SYS Sat Jan 19 00:49:30 2008 (47918F6A)
    8dbec000 8dbf9000 crashdmp crashdmp.sys Sat Jan 19 00:49:43 2008 (47918F77)
    94270000 94471000 win32k win32k.sys Thu Feb 28 23:21:37 2008 (47C78851)
    94490000 94499000 TSDDD TSDDD.dll Sat Jan 19 01:01:09 2008 (47919225)
    944b0000 944be000 cdd cdd.dll Sat Jan 19 02:27:09 2008 (4791A64D)
    944c0000 9450c000 ATMFD ATMFD.DLL Sat Jan 19 00:36:13 2008 (47918C4D)
    9a815000 9a830000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
    9a838000 9a8e7000 spsys spsys.sys Thu Jun 21 20:33:02 2007 (467B18BE)
    9a8e7000 9a8f7000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9a8f7000 9a921000 nwifi nwifi.sys Sat Jan 19 00:53:58 2008 (47919076)
    9a921000 9a92b000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
    9a92b000 9a93e000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9a93e000 9a9a9000 HTTP HTTP.sys Sat Jan 19 00:55:21 2008 (479190C9)
    9a9a9000 9a9c6000 srvnet srvnet.sys Sat Jan 19 00:29:11 2008 (47918AA7)
    9a9c6000 9a9df000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
    9a9df000 9a9f4000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
    9ec04000 9ec24000 mrxdav mrxdav.sys Sat Jan 19 00:28:44 2008 (47918A8C)
    9ec24000 9ec43000 mrxsmb mrxsmb.sys Sat Jan 19 00:28:33 2008 (47918A81)
    9ec43000 9ec7c000 mrxsmb10 mrxsmb10.sys Sat Jan 19 00:28:40 2008 (47918A88)
    9ec7c000 9ec94000 mrxsmb20 mrxsmb20.sys Sat Jan 19 00:28:35 2008 (47918A83)
    9ec94000 9ecbb000 srv2 srv2.sys Sat Jan 19 00:29:14 2008 (47918AAA)
    9ecbb000 9ed07000 srv srv.sys Sat Jan 19 00:29:25 2008 (47918AB5)
    9ed07000 9ed2f000 fastfat fastfat.SYS Sat Jan 19 00:28:00 2008 (47918A60)
    9ed2f000 9ed32180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
    9fc05000 9fce3000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
    9fce3000 9fced000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
    9fced000 9fcf9000 tcpipreg tcpipreg.sys Sat Jan 19 00:56:07 2008 (479190F7)
    9fcf9000 9fd01000 xaudio xaudio.sys Fri Aug 04 20:39:09 2006 (44D3E8AD)
    9fd01000 9fd17000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
    9fd2a000 9fd39000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
    Unloaded modules:
    9fd17000 9fd22000 hiber_atapor
    Checksum: 00000000
    9fd22000 9fd2a000 hiber_atapi.
    Checksum: 00000000
    8dbb4000 8dbc4000 HIDCLASS.SYS
    Checksum: 00000000
    8dbab000 8dbb4000 hidusb.sys
    Checksum: 00000000
    8db92000 8dba9000 usbccgp.sys
    Checksum: 00000000
    8dbe4000 8dbec000 mouhid.sys
    Checksum: 00000000
    8dbc4000 8dbcd000 kbdhid.sys
    Checksum: 00000000
    9a806000 9a815000 monitor.sys
    Checksum: 00000000
    9a830000 9a838000 drmkaud.sys
    Checksum: 00000000
    84bce000 84bdb000 crashdmp.sys
    Checksum: 00000000
    84bdb000 84be6000 dump_ataport
    Checksum: 00000000
    84be6000 84bee000 dump_atapi.s
    Checksum: 00000000
    8d9e0000 8d9e9000 kbdhid.sys
    Checksum: 00000000
  5. 2008/06/05
    bigtwenty
    dump 5
    Loading Dump File [c:\windows\minidump\Mini060508-02.dmp]
    Kernel base = 0x81c0f000 PsLoadedModuleList = 0x81d26c70
    Debug session time: Thu Jun 5 21:41:05.488 2008 (GMT-4)
    System Uptime: 0 days 2:13:50.464
    BugCheck C1, {caedca00, caedc905, d105fc, 23}
    Unable to load image NETw4v32.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for NETw4v32.sys
    *** ERROR: Module load completed but symbols could not be loaded for NETw4v32.sys
    Probably caused by : NETw4v32.sys ( NETw4v32+6b5a )
    Arguments:
    Arg1: caedca00, address trying to free
    Arg2: caedc905, address where bits are corrupted
    Arg3: 00d105fc, (reserved)
    Debugging Details:
    PROCESS_NAME: System
    CURRENT_IRQL: 2
    LAST_CONTROL_TRANSFER: from 81ca6ab3 to 81cdc163
    STACK_TEXT:
    81d0481c 81ca6ab3 000000c1 caedca00 caedc905 nt!KeBugCheckEx+0x1e
    81d04914 81cfcf78 caedca00 caf76fe8 b049a2a8 nt!MmFreeSpecialPool+0x6c
    81d0497c 84899370 caedca00 00000000 81d049a4 nt!ExFreePoolWithTag+0xeb
    81d0498c 848c3e5d caedca00 000005fc 00000000 ndis!NdisFreeMemory+0x16
    81d049a4 8be09b5a caedca00 000005fc 00000000 ndis!ndisVerifierFreeMemory+0x52
    81d049b8 8be0b2a0 caedca00 000005fc 00000000 NETw4v32+0x6b5a
    81d049f0 8be9fd25 b04705e0 00000100 b04f1fc0 NETw4v32+0x82a0
    81d04a24 8be0c4a4 8c2e4e78 000005fc caf02f03 NETw4v32+0x9cd25
    81d04a4c 8be0c6da 8c29aee0 caf76fe8 81d04a78 NETw4v32+0x94a4
    81d04a5c 8be0c2cd caf76fe8 b04f1fc0 b04e5f58 NETw4v32+0x96da
    81d04a78 8be9aa22 8c366ec0 000000da 00000000 NETw4v32+0x92cd
    81d04aa0 8be1af33 8c366ea8 caf02e68 00000000 NETw4v32+0x97a22
    81d04ab4 8be2b732 8cb70ea8 caf02e68 00000000 NETw4v32+0x17f33
    81d04acc 8be0c4a4 8cbdac48 cae18fe8 b04e5f58 NETw4v32+0x28732
    81d04af4 8be0c6da 8cbc0ee0 cae18fe8 81d04b20 NETw4v32+0x94a4
    81d04b04 8be0c2cd cae18fe8 b04e5fa8 81d04b48 NETw4v32+0x96da
    81d04b20 8be3bff4 8cb70ec0 000000c8 00000000 NETw4v32+0x92cd
    81d04ba4 8be16bfe 8af76000 88a0c004 8ae8007c NETw4v32+0x38ff4
    81d04bc8 8be17802 88a0c004 00000000 8cb80e68 NETw4v32+0x13bfe
    81d04bdc 8be192f3 8cb94e58 88a0c004 00000000 NETw4v32+0x14802
    81d04c18 8be194a3 8cb80e68 8cb72e38 88a0c000 NETw4v32+0x162f3
    81d04c54 8be13fc3 00000001 8cb72e38 000000ff NETw4v32+0x164a3
    81d04c80 8be1186c 8cb76e00 8cb72e38 81d04c9c NETw4v32+0x10fc3
    81d04c90 8be04535 8cb72e38 81d04cc4 84950115 NETw4v32+0xe86c
    81d04c9c 84950115 8c3a8ed8 00000000 00000000 NETw4v32+0x1535
    81d04cc4 84891468 8af61e18 8be04520 00000000 ndis!ndisMiniportDpc+0x7a
    81d04ce8 81cc5510 8af61e18 893c30e8 00000000 ndis!ndisInterruptDpc+0xc4
    81d04d50 81cc3f9d 00000000 0000000e 00000000 nt!KiRetireDpcList+0x147
    81d04d54 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x49
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    NETw4v32+6b5a
    8be09b5a ?? ???
    SYMBOL_STACK_INDEX: 5
    SYMBOL_NAME: NETw4v32+6b5a
    MODULE_NAME: NETw4v32
    IMAGE_NAME: NETw4v32.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 46fa5ab2
    FAILURE_BUCKET_ID: 0xC1_23_NETw4v32+6b5a
    eax=81d07920 ebx=caedc905 ecx=81d0f1f8 edx=00000102 esi=81d0793c edi=81d04490
    eip=81cdc163 esp=81d04800 ebp=81d0481c iopl=0 nv up ei pl nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000206
    81cdc163 8be5 mov esp,ebp
    81d0498c 848c3e5d caedca00 000005fc 00000000 ndis!NdisFreeMemory+0x16 (FPO: [Non-Fpo])
    81d049a4 8be09b5a caedca00 000005fc 00000000 ndis!ndisVerifierFreeMemory+0x52 (FPO: [Non-Fpo])
    80609000 80611000 kdcom kdcom.dll Sat Jan 19 02:31:53 2008 (4791A769)
    80611000 80671000 mcupdate mcupdate.dll Sat Jan 19 02:29:43 2008 (4791A6E7)
    80671000 80682000 PSHED PSHED.dll Sat Jan 19 02:31:21 2008 (4791A749)
    80682000 8068a000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
    8068a000 806cb000 CLFS CLFS.SYS Sat Jan 19 00:28:01 2008 (47918A61)
    806cb000 807ab000 CI CI.dll Fri Feb 22 00:00:56 2008 (47BE5708)
    807ab000 807dd000 fltmgr fltmgr.sys Sat Jan 19 00:28:10 2008 (47918A6A)
    807dd000 807ed000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
    81c0f000 81fc8000 nt ntkrpamp.exe Sat Jan 19 00:30:58 2008 (47918B12)
    81fc8000 81ffb000 hal halmacpi.dll Sat Jan 19 00:27:20 2008 (47918A38)
    8220a000 82286000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
    82286000 82293000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
    82293000 822d9000 acpi acpi.sys Sat Jan 19 00:32:48 2008 (47918B80)
    822d9000 822e2000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
    822e2000 822ea000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
    822ea000 82311000 pci pci.sys Sat Jan 19 00:32:57 2008 (47918B89)
    82311000 82320000 partmgr partmgr.sys Sat Jan 19 00:49:54 2008 (47918F82)
    82320000 82322900 compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    82323000 8232d000 BATTC BATTC.SYS Sat Jan 19 00:32:45 2008 (47918B7D)
    8232d000 8233c000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
    8233c000 82386000 volmgrx volmgrx.sys Sat Jan 19 00:50:00 2008 (47918F88)
    82386000 8238d000 intelide intelide.sys Sat Jan 19 00:49:42 2008 (47918F76)
    8238d000 8239b000 PCIIDEX PCIIDEX.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    8239b000 823c8000 pcmcia pcmcia.sys Sat Jan 19 00:32:56 2008 (47918B88)
    823c8000 823d8000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
    823d8000 823e0000 atapi atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    823e0000 823fe000 ataport ataport.SYS Sat Jan 19 00:49:40 2008 (47918F74)
    8480c000 8487d000 ksecdd ksecdd.sys Sat Jan 19 00:41:20 2008 (47918D80)
    8487d000 84890000 DefragFS DefragFS.sys Wed Oct 03 13:01:59 2007 (4703CB07)
    84890000 8499b000 ndis ndis.sys Sat Jan 19 00:55:51 2008 (479190E7)
    8499b000 849c6000 msrpc msrpc.sys Sat Jan 19 00:48:15 2008 (47918F1F)
    849c6000 84a00000 NETIO NETIO.SYS Sat Jan 19 00:56:19 2008 (47919103)
    84a01000 84ae8000 tcpip tcpip.sys Sat Jan 19 00:56:48 2008 (47919120)
    84ae8000 84b03000 fwpkclnt fwpkclnt.sys Sat Jan 19 00:55:44 2008 (479190E0)
    84b03000 84b12000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
    84b12000 84b50000 USBPORT USBPORT.SYS Sat Jan 19 00:53:23 2008 (47919053)
    84b50000 84b5f000 usbehci usbehci.sys Sat Jan 19 00:53:21 2008 (47919051)
    84b5f000 84b71000 HDAudBus HDAudBus.sys Tue Nov 27 18:18:41 2007 (474CA5D1)
    84b71000 84bfa000 rdpdr rdpdr.sys Sat Jan 19 01:02:27 2008 (47919273)
    84c08000 84d17000 Ntfs Ntfs.sys Sat Jan 19 00:28:54 2008 (47918A96)
    84d17000 84d50000 volsnap volsnap.sys Sat Jan 19 00:50:10 2008 (47918F92)
    84d50000 84d58000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
    84d58000 84d67000 mup mup.sys Sat Jan 19 00:28:20 2008 (47918A74)
    84d67000 84d8e000 ecache ecache.sys Sat Jan 19 00:50:47 2008 (47918FB7)
    84d8e000 84d9f000 disk disk.sys Sat Jan 19 00:49:47 2008 (47918F7B)
    84d9f000 84dc0000 CLASSPNP CLASSPNP.SYS Sat Jan 19 00:49:36 2008 (47918F70)
    84dc0000 84dc9000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
    84dc9000 84de4000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
    84de9000 84df4000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
    84df4000 84dfd000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
    8b600000 8b60b000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
    8b60e000 8bd4d300 nvlddmkm nvlddmkm.sys Fri Feb 22 09:52:02 2008 (47BEE192)
    8bd4e000 8bded000 dxgkrnl dxgkrnl.sys Sat Jan 19 00:36:36 2008 (47918C64)
    8bded000 8bdfa000 watchdog watchdog.sys Sat Jan 19 00:35:29 2008 (47918C21)
    8be03000 8c032000 NETw4v32 NETw4v32.sys Wed Sep 26 09:12:18 2007 (46FA5AB2)
    8c032000 8c061000 b57nd60x b57nd60x.sys Thu Feb 08 18:03:14 2007 (45CBAC32)
    8c061000 8c070200 ohci1394 ohci1394.sys Sat Jan 19 00:53:33 2008 (4791905D)
    8c071000 8c07e080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
    8c07f000 8c092000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
    8c092000 8c09d000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8c09d000 8c0a8000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
    8c0a8000 8c0c2000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
    8c0c2000 8c0cc000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
    8c0cc000 8c0e4000 cdrom cdrom.sys Sat Jan 19 00:49:50 2008 (47918F7E)
    8c0e4000 8c0e7780 CmBatt CmBatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8c0e8000 8c0f1000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
    8c0f1000 8c11f000 msiscsi msiscsi.sys Sat Jan 19 00:50:44 2008 (47918FB4)
    8c11f000 8c160000 storport storport.sys Sat Jan 19 00:49:49 2008 (47918F7D)
    8c160000 8c16b000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
    8c16b000 8c182000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
    8c182000 8c18d000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
    8c18d000 8c1b0000 ndiswan ndiswan.sys Sat Jan 19 00:56:32 2008 (47919110)
    8c1b0000 8c1bf000 raspppoe raspppoe.sys Sat Jan 19 00:56:33 2008 (47919111)
    8c1bf000 8c1d3000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
    8c1d3000 8c1e8000 rassstp rassstp.sys Sat Jan 19 00:56:43 2008 (4791911B)
    8c1e8000 8c1f8000 termdd termdd.sys Sat Jan 19 01:01:06 2008 (47919222)
    8c1f8000 8c1f9380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
    8c40f000 8c439000 ks ks.sys Sat Jan 19 00:49:21 2008 (47918F61)
    8c439000 8c447000 cledx cledx.sys Mon May 09 14:08:41 2005 (427FA729)
    8c447000 8c451000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
    8c451000 8c45e000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
    8c45e000 8c492000 usbhub usbhub.sys Sat Jan 19 00:53:40 2008 (47919064)
    8c492000 8c4a3000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
    8c4a3000 8c4f8000 stwrt stwrt.sys Thu Sep 13 11:29:43 2007 (46E95767)
    8c4f8000 8c525000 portcls portcls.sys Sat Jan 19 00:53:17 2008 (4791904D)
    8c525000 8c54a000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
    8c54a000 8c587000 HSXHWAZL HSXHWAZL.sys Thu Nov 02 22:42:16 2006 (454AAC88)
    8c587000 8c5a8000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
    8c5a8000 8c5b0000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
    8c5b0000 8c5bb000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
    8c5bb000 8c5c9000 Npfs Npfs.SYS Sat Jan 19 00:28:09 2008 (47918A69)
    8c5c9000 8c5d2000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
    8c5d2000 8c5e8000 tdx tdx.sys Sat Jan 19 00:55:58 2008 (479190EE)
    8c5e8000 8c5fc000 smb smb.sys Sat Jan 19 00:55:27 2008 (479190CF)
    8e000000 8e00c000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
    8e00e000 8e111000 HSX_DPV HSX_DPV.sys Thu Nov 02 22:43:26 2006 (454AACCE)
    8e111000 8e1c5000 HSX_CNXT HSX_CNXT.sys Thu Nov 02 22:42:05 2006 (454AAC7D)
    8e1c5000 8e1d2000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
    8e1d2000 8e1db000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
    8e1db000 8e1e2000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
    8e1e2000 8e1e9000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
    8e1e9000 8e1f1000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
    8e1f2000 8e1f8380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
    8e40c000 8e454000 afd afd.sys Sat Jan 19 00:57:00 2008 (4791912C)
    8e454000 8e486000 netbt netbt.sys Sat Jan 19 00:55:33 2008 (479190D5)
    8e486000 8e49c000 pacer pacer.sys Sat Jan 19 00:55:53 2008 (479190E9)
    8e49c000 8e4aa000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
    8e4aa000 8e4bd000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
    8e4bd000 8e4c4760 SCDEmu SCDEmu.SYS Mon Aug 06 20:15:06 2007 (46B7B98A)
    8e4c5000 8e501000 rdbss rdbss.sys Sat Jan 19 00:28:34 2008 (47918A82)
    8e501000 8e50b000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
    8e50b000 8e565000 csc csc.sys Sat Jan 19 00:28:54 2008 (47918A96)
    8e565000 8e57c000 dfsc dfsc.sys Sat Jan 19 00:28:20 2008 (47918A74)
    8e57c000 8e580c40 avgmfx86 avgmfx86.sys Thu Jan 10 12:05:15 2008 (4786504B)
    8e581000 8e596f00 avgldx86 avgldx86.sys Thu Jan 31 12:38:23 2008 (47A2078F)
    8e597000 8e5a3000 usbccid usbccid.sys Sat Jan 19 00:49:30 2008 (47918F6A)
    8e5a3000 8e5ae000 SMCLIB SMCLIB.SYS Sat Jan 19 00:49:30 2008 (47918F6A)
    8e5ae000 8e5af700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
    8e5b0000 8e5bd000 crashdmp crashdmp.sys Sat Jan 19 00:49:43 2008 (47918F77)
    8e5bd000 8e5c8000 dump_ataport dump_ataport.sys Sat Jan 19 00:49:40 2008 (47918F74)
    8e5c8000 8e5d0000 dump_atapi dump_atapi.sys Sat Jan 19 00:49:40 2008 (47918F74)
    8e5d0000 8e5da000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
    8e5da000 8e5e9000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
    8e5e9000 8e5ff000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
    93cb0000 93eb1000 win32k win32k.sys Thu Feb 28 23:21:37 2008 (47C78851)
    93ed0000 93ed9000 TSDDD TSDDD.dll Sat Jan 19 01:01:09 2008 (47919225)
    93ef0000 93efe000 cdd cdd.dll Sat Jan 19 02:27:09 2008 (4791A64D)
    93f00000 93f4c000 ATMFD ATMFD.DLL Sat Jan 19 00:36:13 2008 (47918C4D)
    9de04000 9deb3000 spsys spsys.sys Thu Jun 21 20:33:02 2007 (467B18BE)
    9deb3000 9dec3000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9dec3000 9deed000 nwifi nwifi.sys Sat Jan 19 00:53:58 2008 (47919076)
    9deed000 9def7000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
    9def7000 9df0a000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
    9df0a000 9df75000 HTTP HTTP.sys Sat Jan 19 00:55:21 2008 (479190C9)
    9df75000 9df92000 srvnet srvnet.sys Sat Jan 19 00:29:11 2008 (47918AA7)
    9df92000 9dfab000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
    9dfab000 9dfc0000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
    9dfc0000 9dfe0000 mrxdav mrxdav.sys Sat Jan 19 00:28:44 2008 (47918A8C)
    9dfe0000 9dfff000 mrxsmb mrxsmb.sys Sat Jan 19 00:28:33 2008 (47918A81)
    9f80a000 9f843000 mrxsmb10 mrxsmb10.sys Sat Jan 19 00:28:40 2008 (47918A88)
    9f843000 9f85b000 mrxsmb20 mrxsmb20.sys Sat Jan 19 00:28:35 2008 (47918A83)
    9f85b000 9f882000 srv2 srv2.sys Sat Jan 19 00:29:14 2008 (47918AAA)
    9f882000 9f8ce000 srv srv.sys Sat Jan 19 00:29:25 2008 (47918AB5)
    9f8ce000 9f8f6000 fastfat fastfat.SYS Sat Jan 19 00:28:00 2008 (47918A60)
    9f8f6000 9f8f9180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
    9f8fa000 9f9d8000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
    9f9d8000 9f9e2000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
    9f9e2000 9f9ee000 tcpipreg tcpipreg.sys Sat Jan 19 00:56:07 2008 (479190F7)
    9f9ee000 9f9f6000 xaudio xaudio.sys Fri Aug 04 20:39:09 2006 (44D3E8AD)
    Unloaded modules:
    8e5da000 8e5e9000 monitor.sys
    Checksum: 00000000
    8e5e9000 8e5f1000 drmkaud.sys
    Checksum: 00000000
    84dc9000 84dd6000 crashdmp.sys
    Checksum: 00000000
    84dd6000 84de1000 dump_ataport
    Checksum: 00000000
    84de1000 84de9000 dump_atapi.s
    Checksum: 00000000
    8e1e9000 8e1f2000 kbdhid.sys
    Checksum: 00000000
  6. 2008/06/06
    However memory corruption is flagged in 3 of them and if reverting to the original memory resolved the problem case closed :)
    A note about memtest, etc ....
