Office 2003 [Signature problem in Outlook 2003]
Discussion in 'Microsoft Mail (Outlook / OE / Windows Mail)' started by Fredb38, 2008/01/25.
  1. 2008/01/25
    Fredb38
    Fredb38 Well-Known Member Thread Starter
    I have installed Office 2003 on two computers. When in Outlook and creating an E-mail I can go to insert and in the drop down menu their is a says signature. I can select signature and it will place my signature in my message. This works great one one of my computers but on the second computer under insert their is no signature icon. When reading the help files it says that their should be a signatue icon their. Can you tell me how to get that signature icon on the second computer.
  2. 2008/01/26
    If you only create one signature and tell the system to automatically add it, you don't see the icon.
    Fredb38
    Signature
    I would like to set it up so that I can add it manually only. Is their a way to do that and have the signature window show up under the insert menu.
  5. 2008/01/28
    When you edit the signature you created, is the "signature for new messages" set to none? If it is, create a second signature to see if that helps. This will force the system to give you a choice...
  6. 2008/01/28
    Fredb38
    Signature
    I tried what you said but it didn't work. I now have two signatures created but still don't have a choice nor did signature show up under insert.
    Under Insert/Auto test/ signature I have one choice and when selected all it puts in my E-mail is the File name I created for that signature. In other words Fred is what I called that signature and when selected "Fred" is all that is put in the message.
