OE6 - Changing default folder for saving attachments in incoming mail
Discussion in 'Microsoft Mail (Outlook / OE / Windows Mail)' started by amkeew, 2009/01/17.
  1. 2009/01/17
    amkeew
    amkeew Inactive Thread Starter
    The default folder for saving attachments in incoming mails in outlook express 6 is My Documents. How do I change default this to desktop ?
    I know that I can use the drop-down menu while saving attachments to specify desktop as the location and that desktop stays as the default for further saves.
    But I run Javacools' MRU-Blaster often, which restores this default folder back to My Documents. Is there any way to tweak the registry to change the default saving location from My Documents to desktop ?
  2. 2009/01/18
    amkeew
    Thank you Pete C. I have never tried Tweak UI. Should I create system restore point, before I run this ?
  5. 2009/01/18
    Although I have never experienced a problem using Tweak UI - it is basically a Registry GUI, it would be a wise move :)
  6. 2009/01/18
    amkeew
    Thanks Scot. Ran the Tweak UI. I put in the dekstop in all the 5 custom places bar. Rebooted but the OE6 attachment storage folder still remains as My Documents. What's wrong ?
  7. 2009/01/18
