Resolved Odd driver\etc\host problem
Discussion in 'Networking (Hardware & Software)' started by gw1500se, 2012/05/11.
  1. 2012/05/11
    gw1500se
    gw1500se Well-Known Member Thread Starter
    I have a LAN with several nodes on it with static IPs. For a couple of years I have had them all defined in the host file on my XP machine and access worked just fine. I recently migrated a Linux machine from Mandriva to CentOS. When I did the migration I assigned the same static IP address to the new OS, yet I can no longer access that host by name from XP (no changes there). A 'tracert' returns an unable to resolve target system name error. Accessing all the other nodes by name still work fine. I can only access the new OS by IP. I have no clue why changing the OS would prevent XP from using the host file but obviously something has changed. Can anyone help me trouble shoot this? TIA.
  2. 2012/05/11
    Try flushing dns cache.
    gw1500se
    Thanks for the suggestion but no joy.
  5. 2012/05/11
    That you can access the linux system by ip address indicates that it may not ne a networking issue. Check the /etc/hostname file and verify the name is correct. It may be case sensitive.
  6. 2012/05/12
    gw1500se
    Thanks again. It is accessible by name from other systems so it has to be something with this particular XP.
  7. 2012/05/13
    Try flushing the NetBios cache:
    nbtstat -r
    But you should first run netstat -a and check if there any existing connections to the other computer (done by using its IP address as you mentioned above). Kill any existing connections by logging off Windows and logging back on, then flush the caches.
  8. 2012/05/13
    gw1500se
    Thanks but still no joy.
  9. 2012/05/14
    Check the routers tables if possible, remove any mandriva comps min client lists.
  10. 2012/05/18
    gw1500se
    Thanks for the reply. I am not sure I understand what you are suggesting. Do you mean 'netstat -rn'? That looks normal to me. If you are talking about something else, I don't know what "mandriva comps min client lists" are or how to find any.
  11. 2012/05/18
    My typo, it should have said:
    Check the routers tables if possible, remove any mandriva comps in client lists.
    Login to your router, it will have client tables. Check if the "old Linux" system is in any tables and if possible, remove.
    Also, any a security software on Windows comp may be preventing access, e.g. Windows Firewall, antimalware apps, etc.
  12. 2012/05/18
    gw1500se
    I didn't think about the router. However, I have a Linksys and I do not see a way to get or clear any cached data. I did try to reset the router but that didn't help. Its my opinion that the hostname is never really being resolved in the XP host. It behaves like it is simply ignoring that entry in the host table.
  13. 2012/05/20
    Agreed.
    Either there's a 3rd party program that hooks into hosts file lookups, such as Internet security apps or anti-malware apps. These usually work by write protecting the hosts file though.
    Try going to control panel/admin tools/services and set the DNS Client Service to manual and stopped. It's buggy & not needed anyway. This is the service that is responsible for caching DNS names, but it's not that reliable.
  14. 2012/05/20
    gw1500se
    I suppose that was a long shot at best but still no success. I think I need to more closely analyze how I got to this point. Previously everything was working as expected. I then migrated my Linux to a new distro. Post install my Windows XP SEEMINGLY can no longer resolve the original name of the Linux box into an IP. However, I can access it fine with the IP address. So what are the possibilities? Since the only thing that changed was the Linux box it seems logical that the problem lies there. I am going to have to pursue it from that point (CentOS forum) next but I might be back. In the mean time thanks for all the replies.
  15. 2012/05/24
    Can you map the partition from xp?
  16. 2012/05/24
    What's the hostname of your Linux box ? It should be computername.domainname & NOT localhost.localdomain
  17. 2012/05/26
    agreed, and domainname on linux == workgroup on windows. (in not a fqdn)
  18. 2012/06/19
    gw1500se
    TonyT nailed it. This indeed turned out to be a Workgroup issue. The Samba config on the Linux machine had the workgroup misspelled (typo). It seems that Windows XP does not use the host file at all.
