ntbackup.exe does not start with wizard - nor GUI!
Discussion in 'Windows XP' started by Filippo, 2011/04/26.
  1. 2011/04/26
    Filippo
    Filippo Inactive Thread Starter
    - My XP pro SP3 used to run ntbackup.exe alright (FWIW).
    - Now calling it just produces a windowless process that does nothing.
    - I read that the wizard can be disabled in configuration. I am sure I didn't do it.
    - I think I have the original link to the program, which calls it without any options.
    - Calling it in the run dialog without options does the same.
    - Calling it as an unprivileged user makes no difference (it should not start, right?)
    - Process Explorer lists the resulting process as a BATCH (!! default behavior?)
    QUESTIONS
    Is there a switch in the call that forces the wizard?
    Is there a configuration file I can look at to re-enable it?
    Thank you in eager anticipation!
    FCC
  2. 2011/04/26
    antik
    antik Well-Known Member
    Go to Control Panel > Administrative Tools > Services
    See if Removable Storage service is running
    If not, try to start it
    If it won't run, go to C:\Windows\System32\NtmsData
    Move all contents of that folder to a temporary folder
    Try again to start Removable Storage service
    If it starts OK, then run ntbackup.exe
