NT Networking with a Printer?
Discussion in 'Legacy Windows' started by ianripping, 2004/08/25.
  1. 2004/08/25
    ianripping
    ianripping Inactive Thread Starter
    I have two networks - one on Token Ring on on Ethernet. I need to transfer files to one from the other. The only connection that I have between the two netwroks is a printer - HP Laserjet 4. Is there any way of using the printer to transfer files between the two networks?
  2. 2004/08/27
    ReggieB
    ReggieB Inactive Alumni
    No. Very much doubt it.
    The best bet is probably to fit an ethernet card into one of the token ring PCs and then use that as a bridge between the two networks while you transfer the files.
