Notification Help
Discussion in 'Windows XP' started by Nic99, 2004/08/20.
  1. 2004/08/20
    Nic99
    Nic99 Inactive Thread Starter
    :mad:
    I'm having a problem deleting old notifications from my 'customise
    notifications window', I can not seem to find where the files are kept on
    my computer.
    Can anyone help me?
    Nic
  2. 2004/08/20
    Christer
    Christer Geek Member Staff
    Hi Nic99,
    welcome to the WindowsBBS!
    It would help if You elaborate on "notification for what ". I don't think I can help but if You do, someone else may be able to.
    Christer
    Nic99
    Notification Hell-------------- Elaberation
    For instance...
    - WinZip Quick pick
    - Instalation 98% ?
    - AOL
    - TSCC Codec Installation 100%
    - Turbo Zip
    - AD Destroyer
    - Virtual Bouncer
    - Microsoft Office Customer Experiance Improvement Program
    Any help would be greatly appreciated.
    Nic.
  5. 2004/08/20
    crown711
    crown711 Inactive
    Www.blackviper
    i think there you will find what you need.
  6. 2004/08/20
    lj50 Lifetime Subscription
    Start > Run > Regedit > HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Explorer \TrayNotify. Delete IconStreams and PastIconStreams. Exit registry. Open TaskManager go to Processes. Highlight explorer.exe Click End Process when you get the warning dialog box click Yes. While you are still in TaskManager go to File New Task(Run) and type in "explorer" without the quotes click OK. Restart your computer
    lj50,
    #5
