Notepad Max Size 32KB vice 64KB ?
Discussion in 'Legacy Windows' started by RexB, 2004/05/09.
  1. 2004/05/09
    RexB Lifetime Subscription
    RexB groundskeeper Thread Starter
    Notepad is telling me it's full at 32KB, vice the normal 64KB file size limit. Whass' up with that ? :confused:
    RexB,
  2. 2004/05/09
    Daizy
    Daizy Inactive
    While I don't really have an answer for you.....perhaps a replacement would work?
    Thanks Daizy, I liked the looks of that editor, whew! that's for a mega-code-writer.
    Though the author sez {sic} "OK, also in the past few months, I recieved a lot of e-mail saying the print preview and the print function don't work properly, and I have found the problem, unluckily, there will be no workaround, but anyway, it will fix it in the next version as I will going to re-write the whole code for NotePadXP ".
    That link led me to this that is more basic for my simple needs :), no size limit and it prints too, so I downloaded it as a notepad replacement.
    And that {2nd} author might have answered my "32KB" question too: said it is an OS limititation of the Text Editor Window that limits text moves to 32KB. That's beyond me, but is what I was trying to do.
    So you showed me the answer and a replacement editor too! ;)
    RexB,
    Daizy
    Daizy Inactive
    Wow! Imagine the brilliant reply I might have had if I had 2 cups of coffee! :D
    Thanks for posting back. Glad you found your answer.
