Notebook power adapters - basic question
Discussion in 'PC Hardware' started by masonite, 2008/02/08.
  1. 2008/02/08
    masonite
    masonite Well-Known Member Thread Starter
    I have a coupla older Compaq laptops. Their HP-branded power adapters are both rated at outputs of 19volts @ 3.95amps. (I guess the wattage would be 19x3.95=75.o5?)
    BTW, I dunno if this affects the equation but as NZ units, they're 240v input.
    My question: A local supplier of notebook accessories is trying to sell me a replacement adapter which rated at 18.5 volts @ 4.9 amps (approx 90 watts).
    He says... "Hi this one here is the most popular replacement, slightly more powerful which just means it will last longer... "
    Can someone tell me if this is a correct statement? I seem to recall reading somwhen that even small differences in voltage and amperage can be damaging to sensitive equipment.
  2. 2008/02/08
    Rockster2U
    Rockster2U Geek Member
    Your reading is correct - buy an exact match. I'm not going to say that what "the salesman" is trying to sell you won't work but why do you think your computer manufacturer doesn't include a universal one size fits all AC Adapter in the first place?
    Here's a pretty good place to shop without going broke.
    masonite
    Rockster2U, thanks for your response. Unfortunately, buying gear from the US isn't really practical for us in NZ. Firstly, a $US30 item costs $NZ38. Second, freight from the US to NZ frequently costs more than the item. Finally, the power cords are different.
    Cheers :)
  5. 2008/02/09
    r.leale Lifetime Subscription
    r.leale Well-Known Member
    It would work OK, cause no damage if the output is stable, the main thing is - is it made by a reputable manufacturer? The amperage figure quoted of 4.9 amps is the maximum output at which the power can be maintained at 18.5 volts, and I doubt very much that a notebook will be drawing more than 3 amps at any time.
    Roger
  6. 2008/02/09
    Rockster2U
    Roger:
    I appreciate your insight as should masonite. I urged caution because I've witnessed problems with "mis-matched" AC adapters, not just on computers but also peripheral equipment.
    The link I supplied permitted me to purchase an "exact spec" replacement for a Compaq V6000 last week at one fifth of Compaq's going price. Since I made this a gift to one of our house painters, I was a pretty happy camper.
