Not using max udma
Discussion in 'PC Hardware' started by akuakulondon, 2006/10/16.
  1. 2006/10/16
    akuakulondon
    akuakulondon Inactive Thread Starter
    I noticed recently that the two devices running on my secondary ide channel are running UDMA 2 (ATA-33) transfer mode when Everest says the max is UMDA 5.
    Is this affecting my system's performance and if so can I fix it?
    I'd be grateful to hear some advice. Thanks...
    Motherboard:
    CPU Type Intel Pentium 4, 2600 MHz (26 x 100)
    Motherboard Name MSI MS-6701 (Medion OEM) (3 PCI, 1 AGP, 2 DIMM, Audio, LAN)
    Motherboard Chipset SiS 648
    System Memory 1024 MB (PC2700 DDR SDRAM)
    BIOS Type Award (07/05/05)
    Storage:
    IDE Controller SiS PCI IDE UDMA Controller
    Device
    Disk Drive SAMSUNG SP1614N (160 GB, 7200 RPM, Ultra-ATA/133)
    Disk Drive ST3120023A (120 GB, 7200 RPM, Ultra-ATA/100)
    Disk Drive WDC WD400BB-00FRA0 (37 GB, IDE)
    Optical Drive PIONEER DVD RW DVR-109 (DVD+R9:6x, DVD-R9:6x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-ROM:16x, CD:40x/24x/40x DVD+RW/DVD-RW)
    SMART Hard Disks Status OK
    ATA Device Properties:
    Model ID ST3120023A
    Serial Number 3KA1EQPF
    Revision 3.33
    Device Type ATA-100
    Parameters 232581 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
    LBA Sectors 234441648
    Buffer 2 MB
    Multiple Sectors 16
    ECC Bytes 4
    Max. PIO Transfer Mode PIO 4
    Max. UDMA Transfer Mode UDMA 5 (ATA-100)
    Active UDMA Transfer Mode UDMA 5 (ATA-100)
    Unformatted Capacity 114473 MB
    [ SAMSUNG SP1614N (S016J10X329554) ]
    Model ID SAMSUNG SP1614N
    Serial Number S016J10X329554
    Revision TM100-24
    Device Type ATA-100
    Parameters 310101 cylinders, 16 heads, 63 sectors per track, 554 bytes per sector
    LBA Sectors 312581808
    Buffer 8 MB (Dual Ported, Read Ahead)
    Multiple Sectors 16
    ECC Bytes 4
    Active UDMA Transfer Mode UDMA 2 (ATA-33)
    Unformatted Capacity 165148 MB
    Model ID WDC WD400BB-00FRA0
    Serial Number WD-WCAJF1088841
    Revision 77.07W77
    Device Type ATA-100
    Parameters 77545 cylinders, 16 heads, 63 sectors per track, 600 bytes per sector
    LBA Sectors 78165360
    Buffer 2 MB (Dual Ported, Read Ahead)
    Multiple Sectors 16
    ECC Bytes 74
    Unformatted Capacity 44727 MB
  2. 2006/10/16
    Go into Device Manager and expand IDE/ATA ATAPI Controllers. Doubleclick on the Parallel ATA controller to bring up the Properties dialogue and on one of the tabs will be the UDMA setting dialogue - check out what it is and change as necessary.
    Sorry to be a little vague, but I have a different make of controller and I know the arrangement I see is different to others.
    akuakulondon
    That solution wasn't possible on my pc. UDMA modes can't be changed. A friend told me over the weekend there are two types of IDE cable and that the old type only supports UDMA mode 2. I ripped an IDE cable out of an old 386 machine and assume that this must be the problem. It was raining too hard at the weekend to get to the shops but hopefully a new cable will sort the problem!
    Will post back here when I've tested with a new cable
  5. 2006/10/23
    Yes, an 80 core ribbon cable should do the trick.
  6. 2006/10/23
    Chiles4
    Chiles4 Inactive
    It's been my experience that if you use the a 40-pin IDE cable on a 80-pin IDE cable device, you get an onscreen warning during POST.
  7. 2006/10/24
    Two other things I would mention in case you still run into a blank wall.
    Older motherboards did not support 80 lead cables (ATA 100) on the secondary controller. They expected that you would be using optical drives on those. If you notice that the cable connectors on the motherboard are coloured differently, you should check. You will find information by looking up the specifications for the motherboard's model at the manufacturer's website, or reading the section concerning IDE in the motherboard manual. The Dell computers we have at work with 2.6Ghz CPUs are like this.
    It does not sound like the situation in your case, but the UDMA can be set in the drive's firmware by using a utility from the drive manufacturer's website. Read through the descriptions of the utilities that the drive manufacturer offers.
