Not able to open search engine
Discussion in 'Internet Explorer & Microsoft Edge' started by haneefjkt, 2007/03/21.
  1. 2007/03/21
    haneefjkt
    haneefjkt Inactive Thread Starter
    i am using ie6 ,all the web pages are opening except search engines (any search engine, ie-- google etc..
  2. 2007/03/21
    charlesvar
    charlesvar Inactive Alumni
    Hello haneefjkt and welcome to the Board,
    The first check to do is to see if your HOSTS files has an entry that is blocking search engines:
    The Hosts file is located in: C:WINDOWS/System32/Drivers/etc/HOSTS
    Hosts opens with Notepad.
    The standard default Hosts looks like this:
    # Copyright (c) 1993-1999 Microsoft Corp.
    # This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
    # This file contains the mappings of IP addresses to host names. Each
    # entry should be kept on an individual line. The IP address should
    # be placed in the first column followed by the corresponding host name.
    # The IP address and the host name should be separated by at least one
    # space.
    # Additionally, comments (such as these) may be inserted on individual
    # lines or following the machine name denoted by a '#' symbol.
    # For example:
    # 102.54.94.97 rhino.acme.com # source server
    # 38.25.63.10 x.acme.com # x client host
    127.0.0.1 localhost
    Regards - Charles
    haneefjkt
    thakns chrlesvar,,,
    i have entry in host file for my local domino server(email server).i have it in all the pc's .this entry will not block the site......
  5. 2007/03/22
    charlesvar
    Go into IE6's Tools > Manage Add-ons.
    Either disable them all and see if the problem is solved and add back in one by one, or disable one by one.
    One possibilty is you have malware - this is one half of a classic redirect symptom: your anti virus or another security program took care of the redirect portion but left the blocking.
    Regards - Charles
