Norton Ghost 2003 help
Discussion in 'Other PC Software' started by SteveS, 2004/10/02.
  1. 2004/10/02
    SteveS
    SteveS Inactive Thread Starter
    I cannot get it to image my drive.
    I get to dos and the floppy runs and does it stuff, gets a connection to the server then loads ghost.exe, but it just loads the blue/grey ghost screen. No options nothing.... if you press a couple of buttons the machine continually beeps until restarted...
    Ne ideas?
    :confused:
  2. 2004/10/02
    You mention "connection to the server ". A network server? AFAIK, ghosting over the network requires 2 floppy disks with ghost and network support.
    SteveS
    a server i run on my network, it all works fine it connect to the remote server but when it loads ghost its just a blue/grey ghost screen with nothing on it.
    p.s this is with windows xp and i heard 2003 was the only one to support it. i also know it does work this way because we do it at work.
  5. 2004/10/03
    alboy
    alboy Well-Known Member
    Try Here
    Try HERE it may be a good place to start hope it helps
