No sound
Discussion in 'Legacy Windows' started by Bmoore1129, 2015/02/15.
  1. 2015/02/15
    Bmoore1129
    Bmoore1129 Geek Member Thread Starter
    This is a fresh clean install of Win 8.1 retail.
    I have no sound when playing a DVD. I have windows classic and VLC installed.
    I uninstalled the sound driver and rebooted. No help.
    I installed K-lite codec pack. No help.
  2. 2015/02/15
    Hi Bill. Do you hear sound from the DVD if you play it in Windows Media Player?
    Do other video files play with no problems? Which version of the K-Lite Codec Pack did you install?
    Bmoore1129
    The latest version of k-lite, 10.9.5
    I just plugged my earphones into the earphon jack and I have sound now.
    I get nothing from the speaker jack in the back of the computer.
    Thanks for your help...
  5. 2015/02/15
    Ok then. Do you want to try and get the speaker jack working or are you satisfied with the conclusion of this thread?
  6. 2015/02/16
    Since it works with headphones, your sound works. But it is not correct if sound does not flip to your speakers when you unplug the headphones.
    In Control Panel > Sound, do you see Speakers? If so, click on Speakers to highlight then click the Set Default button and see (listen for) what happens.
    Bill,
    #5
