No shift+click to open in a new window...
Discussion in 'Internet Explorer & Microsoft Edge' started by GaryMaton, 2003/05/15.
  1. 2003/05/15
    GaryMaton
    GaryMaton Inactive Thread Starter
    I'm a BIG fan of pressing shift while clicking a hyperlink inorder to open it in a new window!
    The problem is this isn't working anymore!
    Other problems I have noticed have been the "1 new email message" in MSN doesn't work when clicked and also links from inside a program won't work (if you want an example go to "Help" > "About Internet Explorer ")
    I think it is just a Reinstall matter but this in it self hold a problem! The internet Explorer download freezes! Anyone know where I can just download the whole thing and not the one that trys to download it for you?
    Thanx alot,
    Gary
  2. 2003/05/15
    davott
    davott Inactive
    I hold down Ctrl while clicking on a hyperlink to open a new window when I have Pop-Up Stopper enabled. Otherwise, I don't need it. I also see that Shift works just as well, as does Ctrl + Shift.
    Are you using Pop-Up Stopper or a similar program? Try disabling it, and see if you get a different result.
    Gary,
    Download IE 6 to your hdd from here and install at your leisure.
