No Power Schemes Available
Discussion in 'Windows XP' started by murphy903, 2003/11/04.
  1. 2003/11/04
    murphy903
    murphy903 Inactive Thread Starter
    I have a Sony Vaio laptop running XP. I prefer my Power Options to be set at 'Always On'. However, something has happened that shows no Power Schemes available. Also, there seems to be no way to create one. Any advice is greatly appreciated!
  2. 2003/11/04
    Johanna
    Johanna Inactive Alumni
    you have been to Control Panel and Power Options and the power schemes dialog is not there?
    Johanna
    murphy903
    Johanna,
    The dialog box is there but you can't click on any of the functions in the dialog box and there are no Power Schemes to choose from. I can't even create any. Thanks for your reply.
    Mike
  5. 2003/11/04
    Johanna
    forgot to ask, Home or Pro XP? I'll try to search for an answer.
    Johanna
  6. 2003/11/04
    sorinso
    sorinso Inactive
    And most of all, are you logging in with a user that has at least Power User rights, if not Administrator ?
    It sounds like you are a user without rights... Can it be?
  7. 2003/11/05
    murphy903
    This computer doesn't stop to ask me to sign in. That may be the problem. I'm not sure. I am very much a novice with this.
  8. 2003/11/09
    RASelkirk
    RASelkirk Inactive
    In your registry, look under:
    HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies
    There should be subfolders (keys) with numbers from "0" onwards. If the numbers have a gap in the sequence, the power panel properties will be "grayed out" or otherwise unavailable.
    I found this out by making up some custom profiles, then deleting the standard MS profiles which put the key numbers out of sequence, causing the above problem. You can still build custom profiles, but will need to edit the registry key "numbers" in order for it to work.
    Russ Selkirk
