no automatic connection at startup
Discussion in 'Networking (Hardware & Software)' started by bluejay, 2007/05/09.
  1. 2007/05/09
    bluejay
    bluejay Inactive Thread Starter
    I'm running a desktop under Win2k sp4. With a Linksys router. I have wireless connectivity to another win2k desktop and a winXP laptop. TCP/IP with NetBIOS activated on all does the trick. I have internet connection on all as well as file sharing. Took me only about 3 weeks of intensive research and troubleshooting to get it all going! ;-)
    The problem is that my wireless desktop will not connect automatically on startup. Each time I boot, I must enter the configuration utility of the wireless adapter , search for the access point and connect manually. Once that is done, all is fine. The adapter itself is OK, since I earlier had Linux installed on the same PC and the connection worked automatically at boot.
    The laptop connection also starts up automatically at bootup.
    I suspected that some service was operating manually so I tried changing any services that looked like they might be associated with networking to Automatic. Didn't change a thing.
    Any ideas?
    Thanks.
    thebluejay
  2. 2007/05/09
    win2k does not have it's own built in wifi utility like xp does, thus you must use the adapter brand's wifi manager. I suggest looking at the settings/preferences in that connection utility to see if there's a setting to auto connect. And see if any upgraded drivers/connection utility available at the manufacturer web site.
    bluejay
    Not quite that simple. I have been working on this for some time. The Linksys configuration utility for my wireless adapter does not have an auto connect option. Linksys support says the connection should be automatic and suggests something is wrong in the OS or in the card. Its is not the card, because I checked it - runs fine with Linux. So it has to be some Windows networking setting that is messing me up. But I can't find it.
  5. 2007/05/10
    ReggieB
    ReggieB Inactive Alumni
    This sounds like a problem specific to the wireless card drivers and supporting software. When you say "Linksys support says .." is that the feedback from more than one support representitive or just one? It looks to me like the sort of response you can get from a tech. support guy who doesn't know the answer.
  6. 2007/05/10
    bluejay
    I have dealt with about FIVE Linksys support people and they could not help me. They all seem to say that since I have an internet wireless connection, the router and adapter are both working properly so it's not their problem. One suggested I ask Microsoft for help!!! LOL.
  7. 2007/05/10
    visionof
    visionof Inactive
    Hunt around your network connection and wireless utility.
    There is a setting that will make your connecting more promiscuous.
    Something like connect to "non preferred networks on setup "
    I believe that there is a more security conscious setting but i cannot recall it at the moment.
    It is always in the settings - most windows problems.
  8. 2007/05/10
    What brand & version is the card?
    Using DHCP? If using dhcp then access the router control panel & check the client table, the table may still be holding an entry for the card's mac address when it ran under linux.
    I don't recall if can do this in win2k, but if it can, try booting into safe mode w/ networking and see if connection is automatic. If so, then you know that some 3rd party driver or app may be interfering with auto connection, such as a 3rd party firewall or antivirus.
  9. 2007/05/10
    bluejay
    Checked the DHCP Active IP Table and found only entries for the three computers on the network. Deleted and refreshed just to make sure they were all correct.
    Will try safe mode. Already tried with no AV or firewall.
    Stand by...
  10. 2007/05/10
    bluejay
    solved!
    Hey Tony! Guess what! Problem solved, thanks to you.
    The problem was AOL's new Active Virus Shield (AVS). I discovered this by running the wireless PC in Safe Mode with Networking as you suggested. When the connection worked automatically in Safe Mode, it was clearly some application that was blocking the connection. My first suspect was AVS since it is active right from startup looking for updates (even with scanning and startup options disabled). Sure enough, once it was uninstalled, my wireless connected automatically on reboot.
    I initially installed AVS because it was supposed to be less of a resources hog than AVG. Not so. When running in the background, AVS was using around 8M of memory, while AVG used only about 1.5M.
    I have now installed AVG and it works just fine, thanks. I guess AOL is still to be avoided like the plague. ;-)
    Thanks so much for the tip. I've been going nuts with this issue and am so relieved to have finally worked it out.
    Blessings on you, Tony. :)
  11. 2007/05/10
    Glad it all worked out!
    FYI, AOL's AVS is a decent application, it's a stripped down version of kapersky's av program. I dumped AVG for AVS on all my systems now, but on my desktop I have it set to 100% manual everything. I never run an antivirus w/ auto protection, when I need to scan a file I do it manually.
    I suspect the issue you had is unique to win2k because I never ran into any problems using wifi and AVS for my clients w/ XP. When AVS loads at boot it immediately does 2 things: it checks for updates and it scans startup files (other pgms that run at boot). Perhaps the wifi utility could not do it's job because it was "locked" by AVS and its attempts to auto-connect were thwarted.
    If you're happy w/ AVG the so be it. The more important thing is the issue has been dealt with!
