newly installed hard drive works fine as slave, but does not boot as master.
Discussion in 'PC Hardware' started by byron59, 2004/08/08.
  1. 2004/08/08
    byron59
    byron59 Inactive Thread Starter
    Installed a wd 120 gig hd in a Dell pentium III with Win 98 Se. Flashed the bios first. Added Microsoft patches so Fdisk etc. should be able to see larger drive. Copied files from old slow drive.
    New drive works fine as a slave, but will not boot as master or single. Bios shows it as it is supposed to be----but Fdisk shows it as actual less 64.
    What is going on here? How can I get it working?
  2. 2004/08/08
    dobhar Lifetime Subscription
    dobhar Inactive
    Hi byron59...
    I'm going to assume that it is a EIDE WD 120 GB. Are the jumpers set correctly for Single or Master? EIDE Jumper Config => http://support.wdc.com/techinfo/general/jumpers.asp
    - "The full capacity of drives 64GB and larger is not recognized by FDISK and FORMAT in Windows 98/98SE " => http://wdc.custhelp.com/cgi-bin/wdc...HNvcnQ9JnBfcm93X2NudD02OTAmcF9wYWdlPTE*&p_li=
    - "Fdisk Does Not Recognize Full Size of Hard Disks Larger than 64 GB " => http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
    - "How do I use Data Lifeguard Tools 11 to install, partition, and format a drive larger than 137GB (128GB binary) for Windows 98SE/ME? " => http://wdc.custhelp.com/cgi-bin/wdc...HNvcnQ9JnBfcm93X2NudD02OTAmcF9wYWdlPTE*&p_li=
    HTH
