Newbie Help
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Padder, 2003/02/15.
  1. 2003/02/15
    Padder
    Padder Inactive Thread Starter
    Hi, I've recently started using Netscape (7.01) which I find excellent. Problem is I'm having some Windows issues (XP Pro) and think I may have to format and re install. Can I back up all of my favourites/passwords etc so I can just load them in when I reinstall? Prob a really stupid question with an easy answer, I know. Tried looking in the help section on Netscape but it wasn't much (help).
    Thanks in advance:)
  2. 2003/02/15
    Dennis L Inactive Alumni
    Hi Padder
    Sorry to hear your looking at a OS re-install. To get yourself and Netscape ready for the journey, use
    Ramona's PC to PC Tranfer. Go down one click, to the paragraph Back up the Profiles folder to your storage media and start from there. Good luck. Post back
    Padder
    Probably be later in the week when I re-install so thanks for the info. Looks simple enough
