new system build problem (graphics)
Discussion in 'PC Hardware' started by jenks, 2005/10/27.
  1. 2005/10/27
    jenks
    jenks Inactive Thread Starter
    Hi all.
    I have recently built my self a new machine, and am having problems every now and then my screen goes pink and then back to its normal coulor, i also get loads of differnt shapes and colors when i boot some times. which renders my machine useless. i have installed all the latest drivers and updates but still no change, any help would be great.
    asus a8n sli premium mobo
    athlon 64 3000+ cpu with heat sink
    1 gig adata 3200 ram dual channel
    nvidia geforce 6600 gt 256 pci express
    wd 250 SATA hard drive
    mercury 450 w psu
    xp home
    cheers.
  2. 2005/10/27
    Uninstall and remove the new graphics card - clean up the contacts with a soft pencil eraser and reinstall. If this fails to resolve the problem there is the possibility that the card is faulty.
    Any chance of trying another card and/or another monitor?
    jenks
    will give it a whirl and let u know the out come
  5. 2005/10/31
    jenks
    hi
    i tried what u suggested and had no joy, so i took my card back and had a new one but am getting the same results, the monitor is fine. but i did come across something don't know if its relevant, when i uninstalled the drivers, and cleaned connectors, i reinstalled and it said that the drivers where already installed and do i want to overwrite them, even though i uninstalled through control panel and even uninstalled the display adapter. i did try a 6600 128meg, for a short period and seemed OK. do u think it might be a compatibility issue with the a8nsli premium, its doing my nut in big time. cheers for your help.
    jay.
  6. 2005/10/31
    Hi Jay,
    I have a feeling that it relates to monitor drivers. Did you get a drivers CD with the monitor? Check at the manufacturers website for updated drivers.
    Let us know if there is any change by installing/reinstalling those.
  7. 2005/10/31
    jenks
    hi again, and thanks for your help, it did not come with any drivers, but will have a mooch online and see if there are any, it's a acer al1715 17" lcd. i shall let u know.
    jay.
  8. 2005/10/31
    Also get the latest drivers for the graphics card. Either from the manufacturer of your card, or directly from NVIDIA.
    I have the same motherboard, running it with a 256MB eVGA GeForce 6800 GT (PCI-E) graphics card.
  9. 2005/11/04
    jenks
    hi again,
    i tried another monitor and so far so good, will let u know how it goes.
    but thanx for all your time and help.
    Jay.
  10. 2005/11/04
    Pink colours on a CRT monitor can be a bad sign.
    I would be hoping that it may still possibly be a monitor or graphics card drivers problem. Try running the monitor on another computer.
    I had a look at a monitor troubleshooting site. Since it changes from good to bad and back again, it may just be a bad solder somewhere...troubleshooting test, see if whacking it has any effect :D (Brings back memories of the early days of television). Describe the problem to a TV/monitor repairer. See if you can get a free quote for repairs, hopefully it will just need resoldering.
