network help [slow network]
Discussion in 'Networking (Hardware & Software)' started by DeeLay, 2007/07/13.
  1. 2007/07/13
    DeeLay
    DeeLay Inactive Thread Starter
    Ok my laptop is finally running and in which I am on. I neesd to know why the network is so ridulously slow. like dial up. Does anyone know anything that might speed up the resolving of domain names? It seems like a problem which is common.
  2. 2007/07/13
    surferdude2
    surferdude2 Inactive
    Try OpenDNS and see if you get any relief.
    It caches the resolved DNS in a remote super fast server so that you don't have to do it each time you visit a site.
    This service was launched one year ago and I wonder how I ever did without it! I hope you find it the same.
    Commmon causes of network slow downs in no particular order of importance:
    1. malware/spyware
    2. network misconfigurations
    3. isp has some problems
    4. client software misconfigurations
    5. own hardware failing (router, modem, network card, cables)
    Solutions:
    1. post HijackThis log in the Reemoving Spyware & Viruses forum here along with detailed explanation of your problems and with some stats such as download/upload speed test results.
    2. check your networking settings on comp.
    3. call isp.
    4. check browser settings.
    5. reset router to defaults and reconfigure; power modem off & on; check any cables.
  5. 2007/07/15
    visionof
    visionof Inactive
    1) run spyware removal programs - several of them. All find different things
    2) check the settings on the wi fi in the router
    - change the channel from channel 6 to channel 11 or a start
    3)make sure router is high and uncluttered
    4) what are transmission settings in the router ?
    speeds , try changing mru
    5) If the network cards are all g then set to g only
    - if you have one b in the g network it will bring the wireless network down to b speeds ( including wireless printers)
    6) if the network is open you may have an intruder
    network magic will build a map
    - wi fi generally goes at 1/2 of stated speeds as a max. The speed rapidly decreases with distance ( after about 30 feet it starts to drop off like a stone)
  6. 2007/07/16
    DeeLay
    Exactly what the doctor ordered.
    The DNS server was not resolving and after changing to this open DNS low and behold pages came up rapidly. I thought of this being some network issue. but strangily enough the DNS server was not being obtained automatically. I could not possibly have had any spyware on a fresh install of windows. Thanks for the help yet again.
  7. 2007/07/16
    surferdude2
    DeeLay, I'm glad it was the answer for you. Thanks for the feedback so others may benefit. It's one of those cases where you would be looking a long time for some fault in your system when none really existed. ;)
  8. 2007/07/17
    ReggieB
    ReggieB Inactive Alumni
    Don't underestimate how quickly spyware can get on to a PC if you are not careful.
  9. 2007/07/17
    DeeLay
    agreed
    But I couldn't even get on the network to get an installed. I do understand that spy / adware can disrupt the network even in gaming. but in this instance I was having several issues with the installation of windows and a toshiba satellite s504-5005 everything from the installation hanging up to complete crashing and also incomplete installation. but I got the system finally installed with a seem to be working copy but it turned out it was not obtaining an address until after about 5 to 10 minutes. But very true and well deserved advice on all aspects. thanks to all for the tremendous help. I am glad this site exists!
