Network Adapter Identification
Discussion in 'PC Hardware' started by Dan, 2002/01/08.
  1. 2002/01/08
    Dan
    Dan Guest Thread Starter
    Does anyone know how i can find out what Network adapter i have on a 95 machine. It's embedded so i have no idea what it is! Any help would be appreciated.
    Dan.
    Dan,
  2. 2002/01/08
    Ski52
    Ski52 Inactive
    Don't know if this works with an imbedded NIC or not. Look at Control Panel>Network. Ths first screen lists the installed or recognized hardware. Maybe it's listed there. Mine lists Realtek Rtl etc.. & CNET Pro200 etc..
    Good luck
    Ski :)
    Cliffh
    Cliffh Inactive
    Check around on the motherboard, look at all of the large chips, especially those nearest the NIC connection. You might be able to find the manufacturer's name and chipset number on one of them.
    The best bet though is to go to either the system manufacturer or mo/bo manufacturer's web site and download the correct drivers for the NIC. A lot of the onboard chipsets are modified or built specifically for use with a certain system and/or mo/bo.
  5. 2002/01/11
    shawbob
    shawbob Inactive
    You should also see it listed in network properties, unless it is set up with generic drivers.
