Netscape 7.1 email printing problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Bob Curtiss, 2004/04/06.
  1. 2004/04/06
    Bob Curtiss
    Bob Curtiss Inactive Thread Starter
    I use Netscpe 7.1 for browser and email. Something I did in email caused the entire email routing to print when I print a messae. How do I undo this 'feature'? I can't find anything about it in Netscape's help files.
    I see the full header and when I print it all prints. When I click the button to remove the full header the screen displays only the message text, but when I print it, the full header prints which I don't want it to do. Can you tell me how to turn it off? Or what .ini or .cfg or ??? file has the flag? I think its a bug in Netscape 7.1 which can turn it on but not off.
    Bob Curtiss
  2. 2004/04/06
    markp62
    markp62 Geek Member Alumni
    I moved this from Test Posts.
    captjlddavis
    captjlddavis Well-Known Member
    Bob,
    Do you have Mnenhy installed ?
    If I remember right, "none" to supress header was one of its options.
    "None" is not an option in default install.
    Hope this helps
    regars:captjlddavis
