Need to uncheck "extend desktop" in monitor properties
Discussion in 'Windows XP' started by JerseyShore1064, 2007/08/18.
  1. 2007/08/18
    JerseyShore1064
    JerseyShore1064 Inactive Thread Starter
    Running home xp on Dell 8250 no problems for several months until today. I attached an external hard drive to usb port, computer stopped responding, I restarted and now have got an extended desktop which I don't want. Went to desktop properties/settings and the "extend the desktop" is checked and grayed out. I tried changing to the secondary monitor to try to uncheck it but wasn't able to. I am in the process of scanning and printing out several wedding photos and need the stationery screen. Any help is appreciated.
  2. 2007/08/19
    XAMP
    XAMP Inactive
    check your bios settings for your video card they may have changed
    XAMP,
    JerseyShore1064 - Welcome to the Board :)
    Not quite clear from your post as to whether you are running two monitors or not.
    Best suggestion - reload the video drivers, something is fouled up.
  5. 2007/08/20
    JerseyShore1064
    Thanks so much for your replies. After worrying about working on my photos after my post, I decided to just try restarting the computer. Sure enough everything went back to normal. Many times restarting takes care of some problems. I will keep in mind your suggestions if the problem comes up again. Thanks again.
  6. 2007/08/20
    Yup - if in doubt - reboot - Solves a miriad of problems :)
